Unaided night vision even now in the 21st century is still the subject of some controversy.
For those just looking for an executive answer as to what supplemental lighting should be used to reduced the recovery time back to night vision (dark adapted or scotopic) here it is: a fully dimmable white light! This of course is a very incomplete answer but so are the answers red or blue-green and you should know why.
Lets start with red, specifically what I will call the red light myth.
I believe the myth started in the photographic darkroom.
Until about 1906 most photosensitive material (plate, film, and paper) was not very sensitive to red. Some of these orthochromatic materials are still used. This allowed these materials to be dealt with for a short time under a relative bright red light because the human eye can see red if the level is bright enough. The fact that L.E.D.s (having a number of advantages over other light sources) were economically only available in red for some time has also help to perpetuate this myth.
As more research about the eye was done it was found that the structure responsible for very low light vision, the rods, were also not very sensitive to red.
It was assumed then that like film you could use red light, which is seen by the red sensitive cones (there are also blue and green sensitive cones to give color vision), without affecting the rods.
It takes a while for true night vision to be recovered. About 10 minutes for 10%, 30-45 minutes for 80%, the rest may take hours, days, or a week. The issue is the chemical in the eye, rhodopsin - commonly called visual purple, is broken down quickly by light. The main issue then is intensity; color is only an issue because the rods (responsible for night vision) are most sensitive at a particular color. That color is a blue-green (507nm) similar to traffic light green (which is this color for a entirely different reason). It would seem that using the lowest brightness (using this color) additional light needed for a task is the best bet to retain this dark adaptation because it allows rods to function at their best.
I always use green and not red.
