Comparison question/request ZLT+LS-MiniMag & ARC-LS
Klaus
Germany
As the ZLT+LS-MiniMag convinced me of the LS I just had to order one of the SLS Peter offered - so waiting for my white SLS which should be ready this week - or so ....
But one question comes to my mind (and it will be awhile befor I can test it myself)
How does the ARC-LS compare to one ZLT+LS-Mag - I don´t know if anyone owns both and can test this ?
Also in all the ARC-LS runtime tests there never showed up any NiMh cells - I saw some of the testers mention they would do some tests with those cells but nobody seems to have posted any results yet ?
Regards
Klaus
You can "customize" the ZLT+ minimag for a higher output....so it is brighter. But does not last as long as the ARC LS this way, of course.
In terms of a bomb-proof, solid design, I'd go with the ARC LS, of course. But the ZLT+ minimag is definitely a formidable competitor, being a similar size and taking similar batteries. (I say similar batteries b/c I think most people would use nimh in their ZLT+. While I use nimh in my ARC LS as well, I think many use regular alkalines or lithium(s), CR123 included.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Klaus:
How does the ARC-LS compare to one ZLT+LS-Mag - I don´t know if anyone owns both and can test this?
<HR></BLOCKQUOTE>
I'm quite sure the ARC LS has a better working switch
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by remuen:
<HR></BLOCKQUOTE>
that is arguable...while it's hard to tighten down a maglite enough to smush a battery i've read many reports that a arc-ls can do this without difficulty...with alkalines no big deal, with rechargables maybe a bit more...and something about the battery being tightened into the circuitry of the light to turn it on bothers me...
When my ZLT+ LS mod worked
is was noticeably brighter than my ARC LS is with 2 AA lithtiums.
It's hard to put into words but it was almost the difference between the ARC LS 1 AA & 2 AA battery packs! And yes, the ZLT got warm pretty quick.
I was going to send it to the LED Museum to test but the transistor burned up shortly after I began using a tailcap switch, LED still works great, maybe it's time to get it working again and do some comparison photos.
As far as how long NIMH last in either one, I don't have a clue.
Thanks to all for responding so far
But seems I´m right that noone has both parts (working) on hand
But regarding the NiMh runtime of the ARC-LS I would still be very interested
And I fully agree that I expect the ARC-LS to be better engineered than a MiniMag and while the ZLT+ is a great DIY project I would expect Peter product to be ahead - but regarding Seans comments regarding brightness - I was re-re-reading some of the old LS threads and Peter once mentioned that after some initial spike to 340ma the circuit would be at around 250-280ma for hours - I think most of the ZLT+-ses were tuned to around 340 and so obviously should be quite brighter.
Very high on my wish-list would still be that one of our testers would run NiMhs in the ARC-LS to complete the runtime-graphs and also co-run one ZLT+ in comparison.
Klaus
Larry,
the ZLT is a circuit driving the LS with full power from 2 NiMh cells and is designed to fit in a MiniMag head - lots of threads here on that one - also named Zetek300 as this is the chip used.
The whole project is nicely documented at
ZLT+ page
Its not a complete product up for sale but a CPF DIY project based on the work of some members who did a FANTASTIC job on this circuit.
Klaus
There are some runtime charts, not graphs on one of the post, I think duggg and dat2zip charted runtimes w/Nimh batteries, the run time is about 2-3 hours, depending on what you set the current to. My zlt was working fine too, until I fried my LS making some changes to it. and it worked great as a replacement for the original switch mechanism, as soon as I found out that I had to insulate the edges of the circuit board to avoid shorting the circuit inside the body.
InTheDark,
thx
I do know the runtiume of NiMhs in a ZLT+LS
What i asked for is:
a) comparison of ARC-LS against ZLT+LS-MiniMag
b) runtime of NiMhs in the ARC-LS
Klaus
