[ QUOTE ]
tonyb said:
I dont think the everled works that way, the voltage has to be within a certain range and the ouput of the led still fluctuates, correct me if I am wrong. The everled uses a buck-boost converter, I'm engineering a step-up converter so the input voltage is lower than the output voltage, maybe someone else would like to take on that challenge of making a buck-boost converter.
[/ QUOTE ]
Actually, on that note, Linear Tech recently released the LTC3440, a proper buck-boost converter with very nice (paper) efficiency figures. Only problem is it regulates on output voltage, and needs a fair amount of control theory understanding to work with.
I doubt I could pull it off, and I'm busy with another circuit at the moment, but if anyone else wants to try..... /ubbthreads/images/graemlins/wink.gif
Back to the original topic:
An adjustable 5W driver sounds interesting, I would imagine it would be useful in situations where runnning a 5W at full choke isn't desirable, or on the fly adjustment of intensity would be very useful.
I don't quite get what you mean by a pot on the board + an external pot though...
