TriChrome
Hello all, I’m looking forward to my next project which is a Surefire Turbohead incandescent thrower, and just need some confirmation that what I plan on building will work (i.e. that the research I’ve done so far is correct). I want to be able to get the same exact output as a Surefire M6 in the end, but in a smaller (thinner battery tube) form factor like the M3T or M4.
First Lego Version (same output as M3T):
I want to get a Surefire KT4 turbohead, then get something like the Seraph C>M adapter to run it on my existing bored Surefire C2 + 1 cell extender setup (I’m open to other C>M adapters, I haven’t found much info on others, suggestions to match the gray HA Surefire anodizing is appreciated). In that mode I can run 2x 18500’s on the M3T’s M15 or M16 lamps.
Second Lego Version (same output as the M4):
For the next level higher output I can run 3x RCR123’s (IMR or regular, depending on the amperage needed) on the M4’s M60 and M61 bulbs (and other Lumens Factory 12/13 volt offerings). At this point I’ll probably bite the bullet and get a M3 so I can use the D36 drop-ins I already have, with the bonus of getting a proper Surefire 3-cell body to use in the above setups without the C>M adapter.
Third Lego Version (same output as M6):
What I’m a little confused about is getting the same output as the M6 with its MN20 and MN21 bulbs. The Surefire M6 is only a 9v setup, right? But the two 3x CR123 carriers are in parallel so the amperage and mah is doubled? And the M6’s 9-volt setup is somehow brighter than the M4’s 12 volt setup? So to get the same exact output as a Surefire M6 (with less runtime of course) I would need to run a MN20 or MN21 bulb on 2x 18500’s (or for better runtime 2x 18650’s)?
Since the M6 is supposed to be the most amazing output of all Surefire lights, I need to make sure that the KT4 head is the EXACT same head the M6 uses; same reflector, bulb socket, everything. So when I run the correct combo (voltage) batteries on the M6 bulbs (but with the thinner M3T style tube I want to use) the output will be identical to the M6.
Thanks for all the help, and please correct away if I’m off on some of my information.
