xbrite
Hello guys,
Is there any good adjustable Constant current circuit with step up regulator for 2 NiMH application you know of??
I think the Madmax seems a simple step up voltage regulator so the current thru the LED goes up when the LED is heated up which in turn lowers the Vf. I don't know about the Badboy but it seems that the internal current limit of the output transistor determines the output current and I don't know how the current is adjusted.. Correct me if I am wrong..
I have a decent circuit with the step down regulator IC using an external voltage reference, a rail-to-rail OP amp and a current sense resistor of 0.05 ohm stepping down from 2 Li-Ion cells(7.4V nominal) for both 1W and 5W.
I tried once a Step up regulator with 2 NiMH which worked pretty good at voltage mode but once I added an OP amp, a Voltage reference and a sense resistor, it didn't work properly any more. The current didn't stay stable but varied as the battery voltage dropped. I could not make it stable thru out the battery discharging cycle. I guess the supply voltage of the OP Amp is not high enough as I only applied 2.4V.. I later modified B+ supply from battery to the output to LED which is 3.2V approx but it didn't help..
Thanks for the help in advance..
