45/70
Point taken, but I was surprised to discover that actually one doesn't have to program most hobby chargers each time one uses it assuming one is just using it to charge the same type of Li-ion cells each time because (at least with the unit I have) the charger always powers up with the same settings that were used the previous time.
This is a bad habit to develop when charging Li-Ion cells with a hobby charger. There is always the possibility that say, you've been charging 1-4 cells in parallel, as I usually do with my 4 bay cradle and you're "just sure" the last time you were using the charger that you had it set up for charging a single 16340 cell at 400mA, but in fact you had last used it to charge 4 18650 cells @ 5A (1250mA/cell). Unless you notice the Amperage setting (as you should, but......), you could conceivably place a 16340 cell in the cradle and charge it @ 5A!
There's a lot to be said in favor of chargers like the Pila in this regard. You don't really have to check anything, as far as the charger itself is concerned. Regardless of the capacity of the cells you are charging (provided they are 600+ mAh), you just plop them in and go.
And what's all this "One" business? For years now I've been going by the name of 45/70!
Dave
