KiwiMark
I have 2 of these chargers (WF-139) and they seem to work well - though the charge method is different from the standard one. It occurs to me that the charge should be quicker by not tapering off the current at the end and that the final charge state should be exactly the same as achieved by the standard CC/CV method. The only real difference would be that during the final stage of charging the voltage of the cell is higher while the charging current is flowing than the 4.2V which is recommended as a maximum voltage. But given that the time a cell spends above 4.2V is short - does anyone know what sort of damage that does to a cell? I'm thinking that it would not be much degradation (especially for cells that are not charged often, but would be more of a concern for cells topped up regularly).Charging method:
Constant Current @~250-350mA per channel (seems to vary) with V-test every ~1 second (pauses charging for a fraction of a second to take the reading) till 4.20V V-test is achieved.
Safety Information/Warnings:
- The charging method used here is not recommended by any Li-Ion cell manufacture that I am aware of. On smaller cells charging voltage can reach and even exceed 4.35V. Small protected cells will often terminate the charge via PCB.
I consider rechargeable batteries to be a consumable item that needs to be replaced every few years anyway, but I wouldn't want to cut down the useful life of a Li-ion cell from 4-5 years down to 2-3 years - that would be quite a large hit to the lifetime. If we are talking about cutting down an average lifespan of 4.5 years down to 4.4 years then I really couldn't care less. I am doubtful that the Li-ion year lifespan would be reduced by more than 10% and suspect it would be much less than 5%, maybe only a fraction of 1% - if this is the case I will happily use the WF-139 whenever I like.
I do have a couple of Turnigy hobby chargers that I can use most of the time - but there are times I want to recharge a bunch of different cells all at the same time, having 2 WF-139 chargers & 2 hobby chargers & 2 NiMH chargers means I can charge 8 NiMH cells and a bunch of Li-ion cells all at the same time. But I do wonder about how much or how little the WF-139 charger's 'unusual' charging method affects the life of the cells it charges.
My Turnigy chargers are much better for my 32600 Li-ion cells because I can charge at 2 or 3 amps and get them full in a quick time (and they use the CC/CV method). The 'cradle' chargers are a very convenient & easy way of charging up the 16340 & 18650 cells without worrying about settings - much better option for the average Joe.
There, I said it. :naughty:
