Need a little help making 4x123 work in a 2C. I know about removing the anodizing in the back of the tailcap and making a negative contact point (i.e. steel wool, aluminum foil or very small compression spring.
Here is the problem: The 4x123 keeps the tailcap from screwing down completely. This creates an incomplete contact point between the body and tailcap. With 3x123 the tailcap must be tightened down to complete the circuit / have the light come on.
What is the trick to creating the body-to-tailcap contact point with 4x123? I didn't see any metal washers at Home Depot that would work.
I am using Battery Station 123's.
Thanks for the help.
Neal
Neal
