Converting 2xN into 1x123
etc
Northern Virginia
I have a device that takes these weird and useless and expensive alkaline N cells. I want to convert each 2xN config into 1x123. Is there a plug-and-play tray I can use?
Lynx_Arc
Tulsa,OK
Nope. Only if you can make room for the larger diameter of the 123 and accommodate for length differences somehow as the voltage is I believe in the same range. I have a 2N light that was an incan and I swapped in an LED and stretched the spring and adjusted the bulb and use 1AAA now.
etc
Northern Virginia
It's not a light, but a headset and they are in parallel. So 1x123 would fit nicely.
There has to be a plug-and-play module.
Lynx_Arc
Tulsa,OK
Are they in parallel or side-by-side in series? I suggest finding someone that has a 3D printer to make you an adapter.
