BringMeSunshine
I ran my M21F on turbo while on a walk outdoors in freezing cold conditions, about 3 Celcius. After 40 minutes it dropped down to a low level. I re-engaged turbo and after a short while it dropped down again. So I set it onto high, and it eventually gave up after about 50 minutes from when I started out. This is much earlier than expected. Fortunately I carry an emergency torch, so in this case I was not stranded on an unlit country lane.
So I repeated the test indoors, after about 3 minutes the turbo started to step down ending up at about 44 % of the initial value after a few more minutes. My readings are only approximate. It then continued at that level until after 60 minutes there was a small drop to 40 % of the initial value. I gave up through boredom at 75 minutes. This performance is pretty much as expected from the online reviews of this light.
What is going on?
My guess is that the turbo regulation is controlled by time and temperature. After a few minutes on turbo, the output drops down to a level that allows the temperature to remain stable and comfortable. When running the light in freezing cold air, the heat can dissipate more effectively, and hence the light can run at a higher output level, and hence the battery drains more quickly.
Can anyone confirm this?
It is an excellent light, very nicely made, but I need to be careful not to run it on turbo while out on an hour long walk.
What is going on?
