Convoy S2+ 18350 Nichia 219B 92 CRI
Cobraman502
Hi All-
This is my second flashlight build and all I can say is I'm addicted. This time around I decided to build a compact "floody" with high CRI. So here are the parts.
Nichia 219B 4500K 92 CRI LEDs (Triple)
Copper Triple Spacer
17mm DrJones H17F Driver w/ lucidrv2 - 7135 + FET (this is my favorite driver for the programmability its just amazing)
Convoy S2+ 18350 Flashlight Host
[h=1]10507 Carclo Lens - 3-UP Narrow Spot Optic[/h]Light Mode Operation:
What really makes this light is the driver and how it operates. You can have 1 mode up to 7 modes in 2 groups and have 24 brightness levels to choose from. I have researched may other lights in CPF and a few other forms and I don't see too many with this H17F driver with lucidrv2 on it. The reverse clicky on the Convoy S2+ 18350 body is excellent, very responsive, not a lot of play in the switch and does not take a lot of pressure to engage.
Build:
I decided to try a Nichia 219B triple on a solid copper spacer to disperse the heat buildup from this pocket rocket. The driver has thermal control (PID) allowing for maximum brightness while still keeping the light from self destructing or burning your hand. When it came time to attaching the copper spacer, brass pill and LEDs together to form tight thermal paths I was considering low temp paste solder and a hot plate to make an ideal thermal path, however I already had Arctic Silver thermal adhesive. If anyone can provide any details as to the performance gains out of soldering the MBPCB vs thermal adhesive I may change my mind for future builds. I plan on installing 3 0.9mmX2.4mm tritium vials in the 10507 Carlo lens but I have not yet acquired the tritium.
Light Output:
I don't have the ability to measure the light output in lumens but I could take a few beam shots one its night. I would estimate conservatively at about 1000 lumen when comparing it to other lights of known outputs.
Cost:
$60 with eFest IMR 700mAh battery and shipping. The optic was ordered from LEDSupply.com for $1.50 no tax and FREE shipping.
Product NameModelQuantityPriceTotal
(3) Nichia NVSL219BT 4500K 92 CRI LEDs on 20mm 3XP Copper Noctigon + Pre-Bridged 3XP-NVSL219BT-TRIP1$12.49$12.49
Copper Triple Spacer for Convoy S2+ Hosts - XP-L / XP-G2 / Nichia 219 SPCR-TRIP-S2+-CPR1$9.95$9.95
Deep Carry Flashlight Pocket Clip - Black DC-CLIP-11$1.05$1.05
Convoy S2+ 18350 Flashlight Host CONVYS2+HOST-183501$9.25$9.25
Efest Purple IMR 18350 - 700mAh - Button Top EFST18350-PURPLE-BT1$4.85$4.85
- H17F Spring: QLITE Spring
DRJONES-H17F-17MM1$17.29$17.29
Solder Wire - Kester SAC305 - No-Clean Flux - 0.032" - Lead-Free KSTR-SAC305-031-FT1$0.50$0.50
Sub-Total:$55.38
US Envelope Shipping:$2.75
Total:$58.13
Pics:
http://imgur.com/gallery/KcHx5
I'll update with beam shots later
Thanks,
Cobraman502
maukka
Finland
Nice build and couldn't agree more with the DrJones H17F Driver, it's my favorite too.
Skeeterg
Post your pic again please,can't see it here. Build more I will come. I am to lazy to build one,but would buy one.
Cobraman502
The pic can be seen using the imgur link http://imgur.com/gallery/KcHx5
Poppy
Northern New Jersey
That's a nice build Cobraman :thumbsup:
At $60, for parts, I am a little challenged to consider it a budget light anymore.
I do love the Convoys though, and I have a triple built by James... and love it :)
Cobraman502
If you want a simple driver you can save $14.50 and if you don't mind you LED on aluminum you can save another $5.25. Also if you wanted to save $2.50 move you can go with an XP-E2 triple. For a total of $22.25 in saving dropping the build to $37.75 with an 18350 eFest IMR is pretty good for a triple.
I choose the copper spacer given the heat dissipation properties and the remaining driver and MCPCB were my preference.
What are the specs and cost of the convoy you have?
Poppy
Northern New Jersey
It was a gift from across the seas so I don't know the cost.
It was built by James 3tronics.co.uk
LD-2 6 amp (moonlight) driver 4 mode moon low med high
Triple XPL Hi U6 3A 5000K
custom copper spacer
DTP MCPCB & carclo optic.
It is great that it has a moonlight in such an otherwise powerful light.
The tint is beautiful.
Cobraman502
That XPL HI triple MCPCB is gonna run about $17 if not more. Along with the copper spacer I'm thinking you might be a little more than $60. Might be closer to $80.
Thanks for sharing the details.
wolfgaze
Nice build & nice light... Would love to see some beamshots : )
