T
tarpon
- Joined
- Apr 26, 2007
- Messages
- 6
414797
Thanks, picked one up at Cosco. It's cool, works great. Nice headlamp.
The single AA included isn't bad either.
Both for $35.
414797
So back to Target it goes.....has anyone tried to get the thing back in the packaging?
Yeah, just stuff it in as best you can and wrap it all up with clear packing tape. That's what they'll do at the store anyway before they RTV it.
Yes, they should have used a long strip of velcro instead of two pimple-sized squares. I mean, how cheaped-down did they really need to go on this thing? Did the fraction of a penny they saved using tiny squares contribute significantly to some other area of the light? :ironic: I assume you are aware that there is a third square further along the strap for people with smaller heads.
I cannot get any alkalines or eneloops to work in this headlamp. It appears that the tip of the positive end of the battery on the alkalines and eneloops is too fat and cannot fit to make contact. Has anyone else noticed this? The energizer lithiums have a smaller tip and will fit. It almost appears that they intentionally designed it this way so that you have to buy lithiums.
So are these only available at Target and Costco? I typed in the 414797sku at Costco's website and nothing showed up. Is this discontinued already?
No one in this thread mentioned it so far in this year long thread and all I wanted to know is run-time on low. Reading the specs from someone's picture of the packaging posted earlier in this thread, it shows 16 hours on low. Pretty pitiful compared to the 3.5 days (84 hours) of the Zebralight H50 on low (which also only uses a single AA battery). Also I am wondering if Energizer used their run-time figures with the Lithium batteries or regular alkalines? So possibly the run-time on NIMH or alkalines might even be worse than the posted 16 hours if they used the E2 Lithiums to arrive at that number.
As you can see the Zebralight trumps the Energizer and as a proud owner of a Zebralight H50 already I see no purpose of buying this hard/impossible to find light especially when it starts on high to boot, when I'd prefer it to start low like the Zebralight already does.
Brian cool thanks for the test. I'm sure it will be much lower than 16 hours which would keep me from buying it as I have other headlamps that pull off double that. As to checking the current, give me a step by step in how to do that as I have a DMM I use for guitar work but never measured for flashlight current.
Also from reading this thread in it's entirety, the Costco combo was $35 not $25, unless it was on clearance. The headlamp itself at Target was $29.99.
