kalkwasser
Hi everyone,
I am have some NiMH and Li Ion which I use to run some hotwires/HID.
And wondering what is the optimum technique to discharge and charge them. Maybe this topic has been well covered and mentioned. And I have also read them brieftly.
Just want to sumarize if I have done the correct thing.
1) For NiMH batteries: 7.2V 2000mH (Discharge rate. 0.8C, charge rate 1C)
This is what I do. Since I have read that unlike Li Ion. NiMH batteries prefer to be fully drain before charging them. Hence, I have this battery pack discharge to 6V (1V per cell) before charging them. Usually, it's value is about 8.5V when my charger beep to indicate chargeing complete.
2) For Li Ion batteries: 11.1V 2600MH (3x17670)
For this Li Ion, there is no discharging before charging as I again read that its not necessary to do that for Li Ion. Hence, I "top" them up whenever I think they are "weak". Maybe 20-30 mins runtime on flashlights. Or should I measure it before I charge them again? Setting is 1C charging.
My questions:
1) Is it alright to have a higher discharge rate than a charging rate for both NiMH and Li Ion?
2) And how to determine what charging rate for different capacity of batteries? Etc, a 3.7V 800mH and 3.7V 2600mH?
3) Why there are some Li Ion at 3.6V and some at 3.7V.
Can I use 3.7V setting to charge the 3.6V?
Thank you in advance.
Kalk
My questions:
Kalk
