HazeElctrc
this is my first rough draft of my bang for bick light
I have a few improvements I need help and direction please , I can build it but i dont know the exact math and electric theories to apply to the project
The light pod is from amazon rated at 20v and i used a 10 $ car wiring harness kit for convenience , and i shortened some of the wires , its wired for 2 lights , ( though i might mount 2 on my bike for laughs on the night trail rides ) . Going with one for now and it works great . I got about 1 hour , its powered by 4 18650 cells scavenged from old banks and lights i dont use .
They are wired in series and I would like to know just exactly how many i could wire up and where the danger lies in over loading the system ?
(Most of the electronics are kept in a cheap water bottle in my bottle cage , for trails its fine but it could easily go in a water proof saddle bag !)
So First thing i need to do is get a reliable battery source , id like to get 5 hours give or take a bit , I dont know if thats too high expectations or what ? So i was looking to keep the cost down with scavenging old cells for now . I looked at some e-bike and water bottle battery packs at various ratings, and i really want to come in under 100$ for the battery as this is a bang for buck build .
Second thing is id like to know if its possible to get a high low setting or switch , Im not to sure on where to look for a solution that is water proof or resistant to water as it will be on the bike and sometimes exposed to the elements .
any tips are welcome thanks
test notes from a nice review on amazon :
Pic 1:
Readings taken @ 2 min
1.4Amps @ 13.1v (18.3w total)
Ambient temp: 75F
Housing temp: 104F
9.15watt per led
Pic 2:
1.42Amps @ 12.5v (17.7w total)
Ambient temp: 75F
Housing temp: 98F
8.82watt per led
Note: I took voltage readings at two diff voltages. Most cars run around 13.2v when the engine is on and 12.5v when just ran from a SLA battery (what I had on hand). But both are still drawing 1.40/1.42
Pic 1:
Ambient temp: 75F
Housing temp: 104F
9.15watt per led
Pic 2:
Ambient temp: 75F
Housing temp: 98F
8.82watt per led
