CPF Acronyms/Terminology (NEWBS/NOOBS, Look Here!)
British
France
The OP is lacking:
TIR - Total Internal Reflection.
CONUS - CONtiguous United States
GITD - Glow In The Dark
NIB - New In Box
NOS - New Old Stock (?)
OCONUS - Outside CONUS
Zorzi
I was wondering if the term "mule" could also mean a flashlight with the bare minimum on top of which mods are applied. In this sense, a mule could even lack the emitter and drive circuits. Does that make sense?
Zorzi
archimedes
CONUS, top left
Zorzi
No, I think the term for what you describe is "host" .... A tube or shell that needs an emitter/driver "dropin" to function.
Zorzi
Thanks, Archimedes! What is the reason to make a mule? Is there a special use for that? To test the emitter/driver without the influence of the optics, for example?
Zorzi
caleb_v
I'm sure I've seen HID?
Sent from my iPhone using Candlepowerforums
Full Power
Nova Scotia
I suppose there's a point of confusion when one will see a little light amongst all the terminology.!?
terratec365
UK
mAh = MilliAmp Hours; This is a term of "Capacity" in a battery; a battery with say, a capacity of 2500mAh, with a lamp the draws 2 amps (1amp=1000mA) will last ~1.5 hours.
I would have thought it was 1¼ hours, not your 1½ hours.
Here's how I came to that conclusion:
A lamp drawing 2A from a 2000mAh battery would last 1hour.
A lamp drawing 2A from a 500mAh battery would last ¼ of an hour.
So a lamp drawing 2A from a 2500mAh battery would last 1¼ hours.
A lamp drawing 2A from a 1000mAh battery would last ½ an hour.
So a lamp drawing 2A would last 1½ hours from a 3000mAh battery, not a 2500mAh battery.
H.J.M.
Ottawa, Canada and Marysville, Mi.
Re: CPF Acronyms (NEWBS/NOOBS, Look Here!)
Here are a couple I picked up:
Ti: titanium
otw: on the way
omw: On my way
FL flashlight
HL headlamp
Lm lumens
E. T. A. Estimated time of arrival.
Thank you guys for so much information.
cheers!
HJM
Bullzeyebill
CA
Hello, welcome to CPF. Answer is 100th of an amp.
Bill
