ViReN
LiteFlux LF4 SSC P4
Provided for review by http://www.liteflux.com/
General Description:
Size Comparison: From L to R: AA battery, LiteFlux LF4 SSC P4, AW RCR2 battery.
Body: LiteFlux LF4 SSC P4 is machined from Aircraft Grade Aluminium. The Machining is good, without any flaws. The body is sand blasted and has hard anodizing type III coat for better wear and corrosion resistance. The body of LiteFlux LF4 mainly consists of 2 parts, head housing lens, LED, reflector & Electronics and the battery tube. The head has grooves machined providing good grip to hold and allowing easy twisting operation. The battery tube has machined slots allowing means of attachment either to key chain or to lanyard. There is a laser engraved dot on bezel determining the current position. This helps a lot when you need to know that you have to turn about 1/4 turn anti clockwise to turn on the light in low mode. The Glass Lens of LiteFlux LF4 is AR Coated, you can barely see it in front of the bezel. To ensure that dirt and water does not enter the light from bezel, there is a o-ring seal between glass lens and the bezel body protecting LiteFlux LF4 SSC P4
Pictures below showing side view of LiteFlux LF4 highlighting the structural features. The body walls of LiteFlux LF4 SSC P4 are relatively of good thickness indicating fairly good construction.
Components: Showing from left to right, LiteFlux LF4 Head, AW CR2 Lithium-ion Rechargeable Battery and battery tube. The threads are anodized, thus preventing wear and tear during operation. O-Ring placed behind threads on battery tube offers good water resistance.
Reflector - Smooth: Reflector in LiteFlux LF4 SSC P4 is built from solid Aluminum. The reflector has smooth Finish. SSC P4 LED is perfectly aligned and centered within reflector. Although the Reflector is smooth, the beam very has a very soft transition from Hot Spot to Spill beam. There are no artifacts in the beam.
Perfectly aligned LED
Candle :thumbsup:
Extreme Closeup picture:
The Runtime: The runtime for LiteFlux LF4 SSC P4 with AW Li-Ion RCR2 on High is 45 Minutes until the battery protection kicks in. LF4 SSC Runs in good regulation. For the RCR2 battery runtime of over 45 minutes is very impressive especially considering the total output of about 50 lumens.
Overall it's a very good CR2 based SSCP4 LED Flashlight.
More: Pictures - Beam Shots - Candle Shots - Extreme Closeup Pictures - Runtime
Upcoming: New Candle Shots, Beamshots ...
LiteFlux LF4 SSC P4 is CR2 Battery based programmable LED flashlight. This light is one of the 4 models of LiteFlux Beacon Serials flashlights Series from LiteFlux. as with other LiteFlux flashlights, LF4 is built from aircraft grade aluminium. LF4 has hard anodizing type 3 coating over the body for good environmental protection, corrosion resistance and durability. LiteFlux LF4 also have O-Ring Seals at various locations such as between bezel and lens and between battery tube bezel that provide good water resistance and prevent dust and dirt from entering inside the light. One of the unique features for the Beacon Serials flashlight along with LiteFlux LF4 SSC P4 is a specially designed unique 2 stage twist switch. LiteFlux LF4 SSC P4 has advanced drive circuit, with programmable micro controller offering great flexibility in operation and programming options. Like Other LF series, LiteFlux LF4 ships in beautifully packaged wooden gift box.
Light Features:
- Unique 2 stage twist switch
- Micro controller controlled with extensive programming options
- SSC P4 LED
- AR Coated glass lens
- Supports multiple CR2 Battery types including Rechargeable Li-Ion Batteries
- Can stand on tail, includes diffuser for excellent lantern type operation
- Also included are the 3 different color filters
Candle :thumbsup:
