1011Tristar
The other day I noticed that my Inova T2 (older version) had gotten quite dim, and that it was bright when first turned on, and then dimmed out after about half a second. So, I replaced the batteries, and things were back to normal. I checked the voltage of the two cells after I replaced them, and they both measured 2.85 volts. My question is: what is the usable voltage range of the cells in that light? Since the light is regulated, shouldn't they still put out good light well below 2.85 volts?
