jst3712
Hi, I am new to high-power LED projects, and have done some research, but just need a bit of clarification.
I know this looks long, but please don't get put off because it's all really simple stuff, I promise!
What I want to do is connect 3x Cree XP-G LEDs in one series string. I will be driving the string using a 1000mA LuxDrive "BuckPuck". Basically I just want to clarify a few things before I start buying the parts, as I am finding constant current power supplies and the general operation of these types of LEDs a little overwhelming, especially connecting them together (so please bare with me!) -
My questions are as follows –
1)[FONT="] [/FONT]Does the input power supply need to be regulated for the BuckPuck? The datasheet for the BuckPuck doesn't really say anything, so I'm guessing it doesn't.
2)[FONT="] [/FONT]So the BuckPuck gives out 1A constant current at varying output voltages depending on the load – does this mean each of the 3 LEDs, in my application, will run at approximately 333mA, or 1A?!
3)[FONT="] [/FONT](i) The minimum input power supply for the BuckPuck should be slightly higher than the total forward voltage of all connected LEDs, correct?
(ii) So for my application, I'm assuming 12 volts would be ok? (3.0V to 3.3V forward voltage range for this LED type, multipled by 3 equals 9.0 to 9.9V)… which leads me to my final question...
(iii) So say for example I was to run only 1 single LED and run it at 1000mA, according to the LED's datasheet, the forward voltage would be 3.3V. But because I am connecting 3 in series, the forward voltage would be approximately 3.0V per LED then, yeah?
When answering, please numbers to make it easier to follow.
Thanks in advance.
Thanks in advance.
