MrNaz
I've just finished a mod on a dive light, and have noticed significant differences in the LEDs.
They are are an array of 4x XR-E R2 WG LEDs, each powered by its own 350mA AMC7135 board. When I turn the supply voltage down to about 2.2V, the boards go into DD mode and the LEDs are on, but dimly. At this level, I can see one LED significantly dimmer than the others, one significantly brighter than the others and a different tint, and the other two looking like I've come to expect R2-WG emitters to look.
When I turn the voltage up to 4.8V, the boards go into regulation, and the brightness of the array overwhelms any differences in the LEDs, making it impossible to actually see any difference.
Details of the build can be seen in my build photos here:
http://www.candlepowerforums.com/vb/showthread.php?t=278939
Could the differences be accounted for by the behavior of the driver boards? I expect that they should all be the same, especially when they are running with Vbatt < Vf and thus in DD mode. Or are the differences more likely to be due to variances in the emitters as supplied by DX. Or, could it be that I've damaged the dim one with insufficient heatsinking?
Is there a way around this, other than to have a reference set of LEDs and test each emitter against it before inserting? Is it even important?
