mds82,
Thank you for the info! That is good news. There are many people that do not like the idea of four die in an emitter like the Luxeon V due to heat. Nowadays, the LED technology is far better and more efficient. Now you could do this and pull it off with less heat. With 4 EZ1000 dies, you could really under power the emitter and get similar brightness of the X-binned Luxeon V! Lets assume that the Q5 binned dies are used (based from jtr1962's data): Power each emitter at around 150mA (~0.5W each, ~2W total) and get up to 200 lumens! Power each one at 400mA (~1.3W each, 5.2W total) and expect up to 460 lumens!!!
I remember after the P3 and P4 bin came out, I dreamed up such an emitter as this (4 x EZ1000 die) and played around in Solid Works for a while (instead of focusing on class work
) and came up with this:
(click for larger versions)
I originally posted these pictures in some of my first threads here at the CPF. This was to be used in a dream automotive headlight cluster (4 of these radially mounted to a special heat sink, then focused in the reflector of a big car headlight). I planned the light if it could use the P4-bin die technology. Now, with the Q5 (widely available) and the R2 (sort of available), this would be a killer emitter! Notice I did not consider using even an external ESD diode, and I did not consider the SiC substrate that usually goes under the XR-E die. I was hoping that the dies could be soldered to the traces like the older Lumiled's Luxeon die+SiC chip was. This first picture shows the green solder mask and a possible lens retaining ring, which would be slightly
larger smaller* than the current XR-E's retaining ring (see below), holding a seemingly invisible glass dome. The other two are bare. I have the original files somewhere. I should recapture higher resolution images and re-post them.
Well, I am super happy that the quad die emitter will be around the same size as the existing XR-E. I hope the dies, if they are the more powerful EZ1000 dies, will be tightly grouped together. It seems like Cree is not concerned about space in the XR-E since the bond wires spread out pretty far. Tighter grouping would be great for us Flahsaholics and Modders :candle:. Lumileds could do this easy with their TFFC technology (no bond wires). They could make a Rebel 2-4 times larger in area, group 4 Rebel dies in a tight bunch, and have a great product. They could even update the 4 dies in the existing Luxeon V with the Rebel dies (with a slight emitter redesign). I love dreaming...
-Tony
*EDIT: :sweat:
Oops, I opened my original drawings and found that my drawn emitter was 5mm x 7.95mm. That is much smaller than the XR-E emitter, which is about 7mm x 9mm. The Rebel is 3mm x 4.5mm for comparison. In the above images, just imagine the dies appearing smaller so it can be comparable to what Cree may release...
