Hey guys,
I picked up a couple of these new 3 level Surefire lights to see how they performed.
Basically I wasn't quite satisfied with the output and tint, and decided to "fix" the "problem"
The stock output looks very similar to the output of a P60L. It may be a bit brighter, but the tint is a very cool blue.
The 3 levels are very nice.
Also, these lights have a nice strong spill with the reflector provided.
Here are some #s that I found during testing:
STOCK Surefire G2D
Forward voltage (as measured across the LED still mounted in the head)
Low: 3.11V
Medium: 3.57V
High: 4.02V
Current to the LED:
Low: 90mA
Medium: 360mA
High: 900mA
(The G3D had nearly identical #s, but is pushing 960mA on High)
Lux @ 1 meter on high = 4500
So, then I removed the stock LED and replaced it with a new Cree XP-G R5.
Results of the Mod:
Forward voltage (as measured across the LED mounted in the head)
Low: 2.76V
Medium: 2.99V
High: 3.20V
Lux @ 1 meter on high =6950
To compare, I measured an M60 @5000 Lux running on 2 fresh primaries
Here are some pics to help you see the difference.
I made a tiny aluminum ring to make sure the new emitter was perfectly centered.
I will not be modding these regularly.
I just wanted to share the potential of this simple mod with you guys.
Now, go tear apart your brand new lights!
(this first pic is the fine work of ElectronGuru):thumbsup:
XPG mod on the left in all the beamshots
G2D FYL XPG mod vs stock G2D FYL
G2D FYL XPG mod vs Malkoff M30
Note, the M30 pictured has a nice neutral color compared to my other Malkoffs.
STOCK Surefire G2D
Low: 3.11V
Medium: 3.57V
High: 4.02V
Current to the LED:
Low: 90mA
Medium: 360mA
High: 900mA
Results of the Mod:
Low: 2.76V
Medium: 2.99V
High: 3.20V
