Harrkev
Hi. Sorry if this is old news....
Linear makes a current-mode regulator chip designed to drive white LEDs. The textbook application requires only one resistor, one inductor, and two caps, and one diode (besides the white LEDs) in order to work. It claims up to 80% efficiency. The datasheet lists applications for one-cell and two-cell circuts with varying numbers of LEDs. It even shows a 10-led circuit! You can control the output current with a resistor, or even use PWM to control the brightness (555 + op-amp anybody?).
Linear LT1932
www.linear.com/go/dnLT1932
Linear LT1932
