spencer
First of all, I did this build more than a year ago so I don't remember all of the details. I'll provide some details but I'm mostly going to let the pictures do the talking.
All pictures are clickable to fullsize images.
Host: 2.5D dual bored 4x18650 Mag from FiveMega
LEDs: 4x XP-G2 (I think somewhere in the range of R3 3D) on 10mm boards (Cutter)
Reflectors: Something from Cutter (Reginas? maybe?)
Heatsink: Custom
Driver: Maxflex at 1400mA (1300 maybe?)
Batteries: 4x 18650 (AW-3100mAh)
The host is excellent. It is dual bored, head is finned and scalloped, and body is milled. It has a charging jack which is a good idea but is quite high resistance due to a poor negative connection (small fault for how good the host is). I think there may still be some available but don't know for sure because I haven't been on here in awhile.
The first thing that needed to done was to modify the switch to momentary for the driver. There are details on how to do this elsewhere on this site so I won't go into detail.
Here is the switch assembly and modified base for the batteries. Note the grooves cut into the blue plastic for wire routing.
Holes drilled for wire routing.
More material removed to make room for wires.
Wires soldered and routed.
Everything in place.
Top view:
The heatsink was custom machined by my uncle. It was done in return for some labour. It was designed for the reflectors I used such that when the bezel was screwed down completely, it would put some pressure against the reflectors to prevent them from rattling.
Side view:
Top view:
It ended up being just a hair small so I put some copper tape on about half of it.
I made a centring jig for the LEDs. It was drawn to scale so the outside ring is the same size as the heatsink and the inner circles are the same size as the LED boards.
Printout glued to some random thin steel (I think it came from an old cookie tin):
Steel cutout with LEDs and reflectors:
All lined up. I used a piece of scotch tape around the outside to keep it from floating around.
Epoxied with Arctic Alumina:
Top:
Not certain why I don't have a picture showing it, (using the the below picture as illustration) but I cut small grooves on the bottom of the reflector just above and below the hole for running the wires off the board.
Maxflex with a custom heatsink.
I got a little anxious to assemble and didn't take any pictures during that step. Also, the epoxy on the heatsink for the Maxflex wasn't cured completely and it fell off during installation. I installed it anyway but since the Maxflex is being pushed to its limit, it does have thermal problems. Thankfully the board has built in protection so it throttles the output when it gets too hot to prevent damage. Maybe one day I'll open it back up and put it back on.
Down the pipe:
I don't know off the top of my head about runtimes or lumens but could do a little bit of math and figure them out if you are interested. I'll take comments and do my best to answer questions (if I can remember what I did).
Thanks,
Spencer
Heatsink: Custom
Top view:
Side view:
Top view:
Top:
Down the pipe:
Thanks,
Spencer
