Re: Custom Delrin Button Covers for Sunwayman V10R Ti +
Important note: Since the factory dimensions were sloppy with the stock metal retaining ring and metal button, I changed the dimensions on my replacement button cover and retaining ring in order to get smoother operation.
- Delrin button cover: I made the Delrin replacement button cover slightly larger outside diameter to that it would fit inside the larger metal ring - a combo that produces smooth operation without binding.
- Delrin retainer ring: Since the factory retaining ring has an inner diameter which is too big/wide, the replacement Delrin retainer ring I designed with a smaller inside diameter to cope with the narrow factory metal button. This again gives you smooth operation without binding.
What does all of this means? Since I compensated the Delrin button by making it wider and compensated the Delrin retaining ring by making it narrower, you can't use together both the Delrin replacement button with the Delrin replacement retaining ring. You can only use one of the other, but not both together.
My most sincere apologies if this causes anyone grief/problems - I just want to be upfront about it.
Will
