donn_
Note: I have disabled PM. My email and Paypal address is:
:thanks:
Delghi/DonShock HAIII NAT/Q5 2C M@glite
DonShock Cree XR-E Q5 build with Downboy 1000 driver
FM SS Wide Tailcap for 2x AW C Li-Ion Cells
UCL
WITHDRAWN
(Click to enlarge)
(I have hundreds of lights which are not listed. Email your wish-list!)
SOLD OR TRADED
2C/Q5
A cleverly modded mint M@glite 2C in black.
The textured aluminum reflector from an Ultrafire WF500 was cut down to fit in the Mag's head, which was also machined for fit.
The Cree XR-E Q5 WG emitter is perfectly centered and placed for focus, and driven at 1000mA by a ZXSC300 regulated circuit, with upgraded sense resistor. The light will take up to 9v in, and has been successfully tested with everything from 3x 123A primaries to 2x AW C Li-Ion cells (with either AW or FM extended tailcap). It is currently set up for 2x AW C Li-Ion cells, and is wearing a FiveMega Scalloped SS tail cap.
$100$85+ PPI **SOLD**
2C 5761 hotwire
MagLite 2C-cell flashlight, Pewter color, near mint.
UCL window.
Smooth Litho123 reflector opened to accept 5761 bulbs.
Northern Lights socket/Switch combination for the bulb.
Frosted Phillips 5761 bi-pin halogen bulb, rated 765 lumens overdriven to 1331 lumens.
Tail cap spring replacement connection.
NTC controlled surge protection soft start, with Amertherm SL12 1R010 NTC.
Ceramic blanket insulation in the bell and socket area.
Set up to run 2x AW C Li-Ion cells.
$100$85 + PPI **SOLD**
2D/3C P4 3-stage
Here's a black 2D, set up for 3xC cells. The emitter is a Seoul P4 USWOH on a custom heat sink, with green glow epoxy around it.
The switch was replaced with a 4-way model, running a 0.47 Ohm resistor for high, 22 Ohm for medium and 100 Ohm for low.
The tail cap spring is shortened to fit 3x C cells, and the light can handle either NiMH or Alkaline cells.
Condition is near mint.
$75$65 + PPI **SOLD**
3C M@G HAIII / 2X Cree Q5
Mac-machined 3C M@g, in HAIII finish by wtraymond. Fitted with Malkoff Universal 2x Cree Q5 drop-in. The drop-in will take a maximum of 2x Li-Ions and is currently set up to run on two AW C cells, with a spacer (included). In this configuration, it is putting 1600 mAH to the emitters, and output is 580 lumens.
Many other cell options. With 3x standard C cells, you'll get 320-380 lumens. If you have the charging equipment, 2xA123 cells will get you 500 lumens and super-fast recharge times.
A real scorcher, with perfectly aligned emitters, in 6° Khatod optics, creating a gorgeous hot spot, with a graduated spill pattern.
$250$210 + PPI **SOLD**
"Project Gemini"
Modded pewter 2C M@g, as described on this thread:
http://www.candlepowerforums.com/vb/showthread.php?t=166995
SSC P4 @ 900mA - 1000mA. Runs on 2x NiMH or Alkaline C cells.
The light is completely encased in inner tube, for finish protection and added toughness.
In addition to description on the thread, spring was filed, and wired for lower resistance from 40m ohm down to about 5m ohm.
$100$85 + PPI SOLD
3D Seoul P4 5-stage
3D Mag, black, originally built by DonShock, emitter upgraded by datiled.
Single Seoul SSC P4 U-bin USWOH
Cut down smooth Mag reflector
UCL lens
Glow epoxy around LED
DHS heatsink (bare)
Direct drive from 3 alkaline cells (0.1 ohm resistor)
Approx 1.10 Amps to LED on fresh alkaline cells
Electrolumens IQSwitch for 5 level output; 100%, 50%, 25%, slow flash and fast flash
Excellent condition.
$75$65 + PPI SOLD
1D FM Nickel Plated
Five Mega 1D finned-head mags, nickel plated and bored for 4xAA. Recessed tailcap to hold 64mm cell(s).
ElektroLumens MT-3 3xSSC P4 direct drive for 3x Alkaline cells or 1x Li-Ion.
$175$150 + PPI **SOLD**
SOLD OR TRADED
2C/Q5
2C 5761 hotwire
UCL window.
2D/3C P4 3-stage
"Project Gemini"
$100$85 + PPI SOLD
3D Seoul P4 5-stage
UCL lens
DHS heatsink (bare)
$75$65 + PPI SOLD
1D FM Nickel Plated
