Re: Custom Mag-1xD for sale - order placed!
Hi Will,
Just received the new toy from FedEx.
Thank you very much
Sing
Excellent - that was pretty fast shipping :twothumbs
Will, which c cell did you use for measurement? Besides having 18650 going into the tail.
My future plan is for short regular c cell size, if you used AW c cell for measurement, since it's longer than regular c-cell,
You can cut it shorter for me, by the difference of AW vs regular C?
thanks
Ma
OK,
ma_sha1 and
Visible EM Wave, here is the scoop ...
The AW "C" cell measures (per AW's specs, as I don't have one) 2.08" long, so lets say 2.10" long. By comparison, a standard "C" cell is just shy of 2.0" inches.
Here is the first tube for
Visible EM Wave cut for 130mm as requested - actually cut to about 131mm so that I have room to trim/true the edge:
This is about how much from the end do I need for the threads and the relief - about 0.55" to match the factory "C" - (actually less than that, but you get the idea)
With the tube cut to 130mm (well, 131mm), you have about 0.9" inches, but since we only need about 0.5" for the threads, if we only wanted a "C" cell to fit (even the AW which is 0.1" longer), we can still make the tube even shorter:
With the tube cut to "about" 130mm, this is how a protected 18650 cell would fit - this would be within the thread area, so we would need a PVC spacer to keep the cell centered and somewhat inside the tailcap (which would also need a shorter spring):
So, bottom line:
1)
Visible EM Wave - I can cut the second one to 130mm, or make it shorter/longer/etc. - just let me know.
2)
ma_sha1 - If only using an AW (or C cell), I can definitely make the tube shorter - almost 0.5" shorter - the spring will let you use either cell. Let me know what you would prefer.
Will
