D Lithium rechgeable 3.7v 7500mah-Feeler...
spencer
Saskatoon, Canada
I think I got this now. If you have a good charger that will not charge over 4.35V (it should only be 4.2V max though) then you can safely charge this cell at any current (within reason). So if I were to purchase this charger say then I could charge these cells at the max rate of the charger (7A)?
DocD
guildford england
right we need to make it clear
if the chargeing voltage is above 4.35 volt and your charge rate is above 1.75 amps, you will blow the fuse and this battery is nothing more than a paper weight
max charging voltage to be safe, no more than 4.20v at any time when charging one cell and a terminal voltage of 4.20v for one cell
i think 3 amps is a happy medium
or air on the safe side and charge at less than 1.75amp so if needed the K2 can kick and do it's job, to be safe choose 1 amp or 1.5amp
DocD
guildford england
Please any one look for a battery charger that controls the charging voltage will need to check with cpf'ers like silverfox or lux luthor as i think they have more of an idea than me, may some idea from the two might help out ? or start a thread ?
Benson
So, if you had a series pack of these (without balance taps), does this mean you could balance them by charging at, say, 1.5A till the pack voltage reaches 4.35V per cell or higher, and holding them there long enough to bring all cells up to a full charge?
Not real healthy for the batteries (since K2 doesn't activate until 4.35V, I assume that means the cells are held at 4.35V the whole time), but easy enough to do every n cycles to keep the pack balanced, and just charge CC-CV 4.2V/cell the rest of the time.
EDIT: Read again more carefully, and this actually shouldn't hurt the cells -- the terminal cell voltage is 4.19V regardless of the applied voltage.
DocD
guildford england
As we are moving along here, i'm still looking for a upstanding CPF senior member to handle the USA side of things :poke: so roll up roll up don't be shy.
VidPro
Lost In Space
actually that did not make a lot of sence, is there a slight language barrier in the communications?
if its fused and protected, then it is a good thing, the protection does the job of protection, and the fuse does the job that protection cant because of the delay in the protection curcuit.
protection has a very tiny delay in it actuating, with a fuse added if the user (or charger) goes crasy and inputs wild ammounts in when its charged the fuse breaks backing up the protection limitations.
also a fuse could be just added to the system reguardless of the protection, for quick blow safety on major input output, just to back up the protection, and keep things slightly safer, remember electronics can turn to carbon when treated poorly.
(or that is the way i read it). other things dont make sence.
it is not logical to charge these things very fast anyways, i keep indicating that they are usually large CAPACITY and not usually intended for extreeme input output speeds.
In SERIES there is not any way for single cell Protection to do anything more than Cut-OFF. When the curcuit is "Open" on ONE cell, the curcuit is "open" through the entire series set of items, so no flow of current can exist once ONE protected cell in the series protection engages. this (as usual) disallows for any balancing of the cells as long as they are in series, but STILL prevents ANY cell from going to high or to low, because each cell HAS its protection. Protected but not balancable.
Even "pack protection" with series cells generally works the same way without "balancing" taps balancing connections or balancing protection used in the pack, which is uncommon, but becomming more common.
so unless you put in BAlancing on ANY of this stuff, there will not BE balancing, and IF it really does allow 4.35V (which is possible) for its protection High, then you probably wouldnt want to "test" that at any rate without being very carefull, and knowing how close that is to gassing.
Benson
But it's not logical that you could discharge at up to 12A, and only charge at 1.75A; there's nothin "extreme" about charging at 0.5C, yet initial information was that this was not possible.
But there is -- you can charge at over 4.35V, up to 1.75A, and the cell will not charge above 4.19V. The protection circuit here can shunt current past the cell, and it's this bypass that's protected at 1.75A by a fuse. This is not ordinary protection; it does things other protection doesn't. Think of a 4.2V Zener diode in parallel with the cell, although this is obviously more sophisticated (as the Zener would simply blow with too much current, leaving the cell unprotected).
VidPro
Lost In Space
while most of the time i would agree with you, that just simply isnt taking the facts about what we GET into play. and it also assumes that they have done things that are just not done.
there is no shunting of the power across a battery, even though there could be a post draining balancer, which is how one type of pack protection balancer curcuit works.
if you want to charge the battery at 7amps, be my guest, we learn great things from that, like when i learned that a saft D cell can shoot flames out of it very long distances , when charged at only 1C.
i just think that the idea of using a more volitile and dangerous battery should be done with at least the safety we have learnd from blowing up others. and some idea that a battery has magic protection balancer in it , WHEN they wont even do that with the rest of the stuff? ? sure they Squeese out a battery with some descent capacity today, and suddenly it has in it what no other cell has had before :) in ya dreams :)
if you want to test that, then i hope you post your results, myself just learning from others and testing the smaller cells for the same reactions is sufficent. mabey we can get Plasmaman to sacrafice a few more for the team :)
the only reason i got to even say that, is because after shooting flames out of a D cell from a 1C charge, the user did not POST it, if they had people would be all over it. that which is not seen, does not mean it didnt happen.
uhh have you messed with zeners in this type of application? i find they are generally worthless cheap fix items, that blow power out for nothing usefull, and are only ever applied when making dump and run curcuitry. the zener came about as a BY-Product of a breaking diode :) not as a regulation item. just because logs roll down a hill, doesnt mean we should try and make them wheels :)
i just think if were going to get some cheap cell that barly holds up its own voltage under load, is obviously agressivly high capacity which Generally means its NOT built like a tank or designed for high input-ouput, that we could use it within the logical paremeters of the item, and be happy that we HAVE a battery that is 3 times the capacity of a 18650 and can be used in place of a 18650, where all we had was AIR around a 18650, and limited capacity.
That we have the item that FITs the hole, and uses that hole for to achieve major capacity, but nooo, that isnt good enough , now we are going to try and stuff it in series, charge it in series, and fast charge it :) whats next trying to get 50Watts out of it with a incan heater bulb?
why cant we just be happy with excessivly long runtime from a high capacity , NOT high load, battery?
DocD
guildford england
Hi vidpro and benson
you both right and may i add
1 K2 does not balance cell in parallel K2 is a safety against low amp, high voltage overcharge it WILL NOT act like a balance when 2,3,4 or more cell are in parallel.
2 K2 this not the the real sense of the word protection more a safty system for the cell in there ever day use these are built into battery packs with RC type protection and balance curcuit.
3 K2 does not control the terminal voltage of the cell YOUR charger DOES.
4 K2 thermal fuse is a safety against over discharge greater than 12amps.
this cell has a discharge limit so it must have a charging limit
agm said 3 or 5 amps, but if the charging volts exceed 4.35 v at any time, then its game over
think here if you could pumps 7 amps the cell temp would raise and as it as stated in the K2 there are limit ?
i don't think i'll be doing this, as i just do not need a super fast charge cell if i did i would go buy some LiFe-Po4's
cheers DocD
Benson
Well, the manufacturer says it has it, and it's certainly not being sold at an unreasonably low price for a battery of this size and level of protection.
Well, I might, because I'm quite sure it would work (though it may be hard on the batteries; I'm not quite sure I'm understanding right that the battery does stop at 4.19; it may be overcharged to 4.35), but I'm unlikely to, because to me the main application where charging all the cells at once is useful is the 10-20 AA hotwires, where individual charging and batteries become unwieldy. To me, dropping 4 D cells out of a Mag and charging separately every time, is easier than putting in a charging jack and making sure nothing gets in it when not charging.
But I probably will charge them at well over 1.75A, because the manufacturer has stated this is safe (reversing the misunderstanding of their earlier statements), and because it's actually useful. Results will be forthcoming.
In that type of application, meaning, to dump excess power?! No way! I said you wouldn't do it that way; you'd use a zener, if at all, only as a voltage reference to control a transistor to dump the current for light overloads. They're good as voltage references, but it's imperative to keep the power (and hence the current) within specs, which are usually quite low. Any use of them to directly dump energy is almost guaranteed to overheat and blow them; that was meant only conceptually.
It's 3 times the capacity of an 18650, but it's also 3 times the size of an 18650 -- it's not an amazingly high-capacity cell that should need to be babied. Again, it's rated for 12A discharge (1.6C); that's not out of line for the cells we're familiar with, which are often rated for 2C, but sometimes 1.5C. There's no reason I know to consider 1.75A (0.23C) charge rates "logical parameters", especially after the manufacturer has clarified that the 1.75A limit only applies above 4.35V.
Well, the series charge + balance, as I said, I probably won't try, as it doesn't offer much advantage, and I still have some doubts over whether it's "safe" (cells only reach 4.19V) or whether it just "works" (cells are overcharged to 4.35V, and don't vent at that overcharge). As for the fast charge, it's not a fast charge, IMHO; I thought the term "fast charge", for Li-ions, generally meant over 1C; going 0.3C isn't a fast charge, nor (since the manufacturer has stated they're good up to 5A charge) at all pushing things; recharging in 2 to 3 hours instead of 5+ seems like a good idea, as I don't like to charge unattended.
Pulling 50W? No, they rated it at 12A, so that's only 44.4W -- I'll probably keep it below 25W/cell, actually. Certainly I could use it for low-draw only, like a high-capacity 18650, and I may get a 1D Mag at some point to do just that with a P7, but since it has raised specs in other areas as well as capacity, why shouldn't I use it for higher-performance applications that remain within those specs?
Anyhow, supposing this deal goes down (and it looks promising!), I will post back with results, good or bad, of whatever stresses I put these poor batteries through.
VidPro
Lost In Space
i donno, i look at the graph and that isnt Par for a battery that is going to enjoy high loads, and seeings that the other competitive items are 4.8amp 5.2Amp and 6 Amp, i would assume like all the rest of this stuff generally acts that the 7+ amp one has the same caveats of other high capacity cells.
12Amp possible discharge ??? so, Pulse for how long at what voltage? where is the spec sheet, all i have seen so far is a graph that defined it pretty well, as would be expected.
you can look at THAT graph and define those kinds of paremeters from it, then we must assume that the tester has some flaws in the testing parameters.
analogy:
if i am told that a mazzarati goes 220 MPH , and everyone who buys a mazzarati takes it out on the freeway at 220, wraps it around trees, then Mazaratties become very hard to get ahold of, cost a whole lot , insurance is hard to get on them, and the guberment puts all kinsa restrictions on it and all.
there was a totally cool 60AMP li-ion battery that was easily available on the battery site, now it is no more :-(
we have had Many D battery sales avilable here and they often end , because of high expectations , and low reality, so then we Loose availabilty again, why do we want to take this golden goose and turn it inside out , when we can get golden eggs out of it for years ?
DocD
guildford england
If a usa handler can't be found? then all mine and plasmamans hard work and phone calls are going to go to waste :eek: sooner i hope than later and will turn into a sale thread on the marketplace cheers DocD
spencer
Saskatoon, Canada
Just confirming that the cost of this cell is £30 plus £11 to send it to the states so a total of £41 a cell?
Can someone volunteer to handle this stateside? I really want this to go through.
DocD
guildford england
the cost is £30.00 pounds plus if only 25 go to the usa p&p £11.00, i'm hoping for about 30cells
Please note i have NO idea about the custom set-up in the USA import duty and taxes as this is a bulk package that will past though USA custom hands so if any one could work the duty or tax on the value lets say $1750.00 dollars ( 30 cells x £30 + £11.00 p&p x $1.40 )we might get close to answer:thumbsup:
UK cost are £30.00 + £1.50 + vat= £36.23 to my door based on 25 cells then reset to the new owner £41.00 per cell at your door.
As said before it's all about getting 50 cell i,m hope that the interest shown in this thread will carry over to the sales thread soon to be posted in the marketplace :thumbsup:i'm taking 10 cells for myself so 40 left
i hope this happens cheers and keep reading and showing your interest here thanks DocD
plasmaman
The boat house in Hereford, UK
Phil - don't forget the VAT that will be charged on the sale to you of the cells.
You need a US customer that can be invoiced direct by the factory for the full 25 cell package not only for shipping purposes, but also to ensure the sale of those cells is not subject to VAT.
DocD
guildford england
thanks for the reminder but were sort of still waiting for the USA side of this to be pick-up, by upstanding senior member and with a business address, this is to tick all the boxes for AGM paperwork.
any chance of the link to the Hazmat rules were you read you can send 3cells at a time by airmail? and not break any laws? cheers DocD
VidPro
Lost In Space
once its IN the states, they can be shipped (legally and within all the Rules) by Ups ground, which now has added one more little warning to the package, and mabey a bit of extra paperwork, the air regulations are for the purposes of human transport with luggage, basically the battery shipments now stay on the "ground" (or in ups cargo planes when they decide).
also some of the regs for shipping (USPS) and even tagging, are about the quantity of lithium per shipment, sending 2 (D) might be easy sending 3 , might best be done with 2 packages.
heck USPS will freak out if you send flour :) or an alarm clock , best to keep it simple and send it with the people who will actually deliver it TO the addresses on the package, UPS which means More money, better reliabilty, but no less package smashing.
at any rate MOST of the stupidity in shipping has been flawed by PACKING IMO, weather it has big radioactive flags on the side or not, some peple still cant pack a battery for proper shipping, even if its thier frilling JOBs. argg. so when it comes to How-To about anybody could do better than How-Done, all they have to do is try.
i would rather see a well packaged shipment go by air than the slop jobs of packing that we get by ground.
i have no idea how it gets across the ocean (inc hawaii) , slow boat, or well marked cargo shipment, or put on NON-passenger planes (that is one reason its marked). well i do know some other overseas ways, but not usefull to discuss those.
plasmaman
Just emailed those to you Phil.
