D-mini VX2 / EX2 upgrade info : 1-Apr2016
lumapower
Well-known member
Hong Kong
The new upgrade being apply to both D-mini EX2 and D-mini VX2.
Here are some beamshots reference :
In order to show the real effect appears to human eyes, we use use a higher shutter speed as 1 seconds.
Both D-mini EX2 and VX2 use 3.7V rechargeable li-ion at max. mode.
30 Meter test :
100 Meter test :
And here are the throw readings for your reference:
5 meter lux readings:
1. D-mini EX2 : 570
2. D-mini VX2 : 530
3. Upgrade EX2 : 1050
4. Upgrade VX2 : 920
5. MRV-SK U4 : 1300
To convert the result to 1 meter : readings x 25
1. D-mini EX2 : 14250
2. D-mini VX2 : 13250
3. Upgrade EX2 : 26250
4. Upgrade VX2 : 23000
5. MRV-SK U4 : 32500
So, the throw readings :
1. D-mini EX2 : 239 meter
2. D-mini VX2 : 230 meter
3. Upgrade EX2 : 324 meter
4. Upgrade VX2 : 303 meter
5. MRV-SK U4 : 361 meter
All D-mini test with rechargeable 16340
MRV-SK U4 with 2x18650
All test with standard reflector.
Best regards,
Ricky - Lumapower CS
cirlaccouff
New member
D mini VX2 / EX2 upgrade info 1 Apr2016
Will you be adding start mode to the Cuboid-Mini? *My girlfriend need it to be simple to use
lumapower
Well-known member
Hong Kong
Re: D mini VX2 / EX2 upgrade info 1 Apr2016
I am not sure your meaning of Cuboid-mini.
Our upgrade module with memory to store last output if power on for more than 1.5 seconds.
And aldo tactical lock for any selected level.
Best regards,
Ricky - Lumapower
