spencer
I am in the planning stage of making a multi LED light. Right now the plan is to have 8 crees running off of two sharks. Four LEDs in parallel for each shark. I need some suggestions for the batteries. As the title says I would like to use D cells. I figure that I would need either two or three 3.7 volt batteries. I haven't decided if I want to use two or three batteries yet. I was leaning toward getting KD's 7.4V 5Ah 2 cell battery pack but I just read something that is making me lean away from them.
Awhile ago I saw a thread on someone who was trying to get a group buy on these really high capacity D cell batteries. I never finished reading the thread and haven't been able to find it again. Maybe I should use those batteries?
Anyway, just wondering your suggestions on what I should use. Higher capacity is a plus but I know that at least in the AA world the higher capacity batteries are not nearly as high performing. As you can see this light will be fairly taxing and on high will pull 30 watts (3.7V/LED @1A so 14.8V/string at 1A and 29.6V/all LEDs at 1A). From what I hear I should probably use protected so I don't accidentally kill the batteries. Also, LuxLuthor's packs may also be an option.
