Alaric Darconville
http://www.danielsternlighting.com/tech/aim/aim.html has been revised!
People familiar with this link may have stopped clicking it by now, but it's worth clicking for a reread since it's been revamped. It's got a link to the VW instructions for using the Hella VAS 5107 Universal Beamsetter IV (quite the mouthful), which shows the results for various (VW) cars, but is a good reference for what YOUR vehicle aim should look like.
Also of note is that there are no longer different declination recommendations for ECE and VOL; all these lamps get the VOL declination recommendations. The ECE angles are much too low in Europe, and super extra WAY far too low in North America, meaning extremely curtailed low beam seeing distance.
For those unsure of where to find a shop with an aimer, it gives information on locating those dealerships or shops by way of querying the manufacturers.
Another thing that should go without saying (but I say it a bit, and it's said in this document)-- for many composite headlamps (and, of course, sealed beams) that the low and high beam offset is set within the lamp and is not independently adjustable-- always aim on low beam with such lamps. The high beams will then be correctly aimed unless you have a poorly-designed or just plain broken lamp. Only aim high beams separately if they can be independently adjusted without disturbing the low beam aim (generally, when they are a separate, and single-function, lamp).
Horizontal aim gets more than just a mention, with information on how to check and correct horizontal aim. Note that in the U.S., this function is typically locked out by law through the use of caps over the adjustment screws.
Fog lamps, which should be left OFF are easily aimed and the process is mentioned there.
