[DEAL] NEW HaikeLite MT03 Devourer 8760lm and MT07 Buffalo 5000LM Search light
Wurkkos
Status
Not open for further replies.
freeme
Well-known member
Vendor
1thedeals.com
HaikeLite MT03 Devourer XHP70 8760LM CW/NW High Power LED Flashlight - $129
15% OFF / Coupon: HLMT03 / Purchase Link
Product name:HaikeLite MT03 XHP70 8760LM High Power LED Flashlight
Brand:HaikeLite
Model:MT03
Emitter Type:XHP70
Emitter BIN:N4 Cool white,N2 Neutral white
Material:Aluminum Alloy body with HAIII Anodize black surface Finish
Mode:Ultra low,Low,Mid,High,Hidden moonlight,turbo
Lumens:10LM,150LM,1000LM,2700LM,8760LM,0.6LM
Runtime:28d,35h,550min,330min,58d,2.5min
Battery Configurations:4 x 10A Flat Top 18650 battery (not included)
Switch Type:Clicky (with big Transparent rubber boot)
Switch Location:body side of the flashlight
Max Output:8760 Lumens CW ; 7560lumens NW
Lens:Ultra Clear Double-sided AR coated Glass lens
(99% Light transmision )
Reflector:Aluminium OP Reflector
Waterproof:IPX8 Waterproof
Color:Black
Weight:600 Gram
Size:127mm length x 72mm Head x 50mm body
HaikeLite MT07 Buffalo XHP70 5000LM CW/NW High Power LED Flashlight - $95
15% OFF
/ Coupon: HLMT07 / Purchase Link
Product name:HaikeLite MT07 XHP70 5000LM High Power LED Flashlight
Brand:HaikeLite
Model:MT07
Emitter Type:XHP70
Emitter BIN:N4 Cool white/N2 Neutral white
Mode:Ultra low,Low,Mid,High,Turbo,Moonlight +Sos
Lumens:50LM,450LM,1200LM,2300LM,5000LM,0.3LM
Runtime:228h,32h,18h,10h,5min,98d
Timed Themal regulation Step down
Battery Configurations:4x 10A flat top 18650 battery (not included)
Switch Type:Double side clicky switch,One for ON/OFF, One for mode-changing
Max Output:CW 5000 Lumens ; NW 4500 Lumens
Range:750 meters
Lens:Ultra Clear Double-sided AR coated toughened Glass lens (99%light transmittance)
Reflector:Deep and Big Aluminium light-OP Reflector
Waterproof:IPX-8 Waterproof
Color:Black
Source: HaikeLite
jprince
Member
Quick question I bought this light and I'm not able to get it to work, has anyone else,had this problem of the light not turning on? I've loaded the batteries in the correct way(via manual) but still not having any luck HELP!,,,,
Status
