Fallingwater
I just received this flashlight.
The "Piston" nickname is unofficial, by the way. It just looks kinda like a piston to me.
The good:
I was expecting something with the size and heft of my U2 clone, but it's considerably smaller and much lighter. The Piston with a 18650 in it weighs a bit less than the U2 clone without.
This gives the U2 clone a lot more aggressor-smacking potential, but since the Piston is not meant for any sort of tactical duty the lighter weight is a good thing.
I'm not usually one to choose things for their aesthetics, but it must be said that the Piston just plain looks nice. Not many flashlights look as if they ought to be inside an engine.
The threading on the tailcap feels ok, even if a bit tight. The threads are pre-lubricated, and there's an o-ring that seems to be doing its job.
It has memory, which DX didn't specify. It was a pleasant surprise; you don't have to click through modes every time if you're ok with using it in the mode you used it last.
DX's page says the modes go Mid > Low > High > Strobe > SOS, but in my light they go Low > Mid > High > Strobe > SOS, which makes more sense to me.
It seems bright.
The bad:
The beam is by far the worst I've seen on a Cree flashlight, and this includes my originally-intended-for-Luxeons MXDL 123. It's uneven and very ringy. The plastic reflector is obviously not a good choice.
It's not a crippling problem, because when you're actually using it (as opposed to just pointing it at a wall) the beam pattern's relevance decreases greatly, but still. One of the many reasons I steer clear from incandescents is to avoid seeing this sort of crap.
The deity-damned strobe and SOS modes are there and there's nothing you can do to avoid them (update: actually there is. Read the following posts for more details about this). This was expected, of course, but it's still bad.
I can just believe strobe mode could be useful to someone, but SOS should be banned from all flashlights everywhere, with the death penalty for anyone who builds one with that mode regardless.
Well, maybe the death penalty is a slight exaggeration, but a severe whipping is definitely in order.
The ugly:
The switch is the definition of the term "craptacular". It's a two-stage, which means two switching actions are needed for every mode change. It might be possible to depress it partially to change mode, but I can't tell you because I didn't have enough time to test it before it failed completely.
For a few times it didn't want to pop back out when pressed, and only strongly whacking it eventually caused it to relent. Then whacking no longer did it and it got stuck in pressed-off mode, after not even five minutes from the moment I started using it.
This is also the reason why there are no beamshots and no comments on the light level. I'll post some once I manage to unstick it, or replace it completely.
Other notes:
There's a slight whining noise when it's in low mode, but it's not very loud.
For the very short time while it was actually working, I noticed the flashlight sometimes randomly turns off for a fraction of a second while in low mode and being moved around. I'm not sure if it's a driver defect of a switch defect, although I'm inclined to believe it's the latter.
Conclusions so far:
I'm pretty disappointed. If this was a $12 light I'd go "eh" and consider these shortcomings the price to pay for cheapness, but $25 is supposed to get you better quality from DX. The U2 clone is actually cheaper, and works rather better.
I'd send it back to DX for a replacement if it shipping didn't take so darn long. I'll try to fix the switch myself and see what can be done for the beam. Maybe I can get a proper metal reflector for it.
The good:
It seems bright.
The bad:
The ugly:
Other notes:
Conclusions so far:
