My latest Project:
Death~Ray - 5 Watt LED Mountain Bike Light
Description:
The Death~Ray is a self contained bike light designed to provide night-time illumination of rocky singletrack - at speeds up to 20MPH. It shall clearly illuminate the trail path up to 20 feet ahead. Built in battery and charge port (allows for "plug an play" charging as well as external backup battery connection). It is recommended to supplement this light with a helmet mounted LED of 5 Watts or greater - to provide corner illumination. Handlebar mounting is accomplished through a Loop and Hook O-ring. This lightweight system utilizes the highest density Li-ion power cell and most powerful LED on the market (01/2005).
Components:
1 - 5 Watt Luxeon Star (Premium Bin)
1 - 2400maH lithium Ion Battery (18650 cell)
1 - Li-Ion protection PCB
1 - Taskled – Fatman Boost Driver PCB
1 - Judco Switch
1 - Deans Female connector
1 - 20 mm UCL glass lens
1 - 20 mm S020X reflector
Specifications:
Power: 5 Watt, 750ma (92% efficiency)
Burn time: Approx. 90 minutes
Total System Weight: 180grams
Dimensions: 3.125" x 2.00" x 1.00"
Description:
Components:
1 - Judco Switch
Specifications:
