Deerelight NMvn - Baby XSvn
Skylumen
  • Factory Link Here
  • The small head version of the XSvn
  • Oslon 6500K
  • Ultra focus with no spill beam
  • 300 Lumen, 450Kcd, 1342m Throw
  • This is not a zoomie. Single focus only
  • VTC6 Recommended
$140 Singel Mode
$185 DriverVN4
Email if you want Red, Green or Blue LED :)
flybird
If no spill, Is there a yellow around the corona or hot spot like in most aspherical lens ?
b8llzblue
Wow that looks very impressive! I love it. Are u sure the Xsvn is only 600kcd?
i have lights that are in that range and I don’t think it shines a hot spot like that in the day time.
If it didn’t have those rings, I think I would purchase one. Does the nmvn have those two rings as well?
Skylumen
Wow that looks very impressive! I love it. Are u sure the Xsvn is only 600kcd? Lumen 300, Intensity 675Kcd, Throw 1643m
If it didn’t have those rings, I think I would purchase one. Does the nmvn have those two rings as well? OH yeah it does. I forgot about that ring.
twistedraven
The last shot makes it look like a 10,000 lumen, 10 million candela searchlight.
Skylumen
Here is a beam shot. At any practical distance the ring around the hot spot is 100% non visible.
Nokoff
Cheers, USA 🇺🇸
I assume the control ring doesn’t work any longer so it’s tail cap button press only.
Those are almost as good of numbers as my Delta, tho with much less lumens.
Skylumen
I assume the control ring doesn’t work any longer so it’s tail cap button press only. Correct
Those are almost as good of numbers as my Delta, tho with much less lumens. Its a specialty light for those that doesn't want spill.
Nokoff
Cheers, USA 🇺🇸
Yep I have an aspheric torch already and nothing puts on a better show for friends. They want to see it again and again. This one would blow mine away, lucky whoever gets one, or several like you said. [emoji4]
MBentz
Folsom, CA
Anyone know of a holster to fit this light? Would be perfect for work if I can attach it to my belt.
