Defiant 3C triple 850 lumens
Poppy
Northern New Jersey
The home depot has had these for a while, and now they are only $10.
Defiant
Model # HD15BF01
Internet # 206091479
Store SKU # 1001396908
850 Lumen LED Flashlight
290 meters throw, which calculates to about 22,000 cd.
What is the beam like? Being a triple, I imagine that it might be a general purpose camping flooder.
Edit... these lights ride in my trunk.
AW9zlfovMafCWIOhcHaThWBSZLvcvhN5o3VGXv-N-I2CrKA6937VdULFCmNa3FB85SH1vOZ4gDNOZczAdfsyXXA71L84WJnOX47L-TLJa82tNhR1bHf6991IEpW7Uanm9TDIEailbO4w7QR35VfsCavjrtu9w1HIEPleMbA6J9tp-gicdfn-iY_2Myc_7_kgPrKNmogXoI6-D-Gfa97f47hJHcNhFVm28Iu9etfr-f33YW1mbgdf9NJghUS5m4wHogLdL6w9L1FhdAdMmLJWqu2dVyHze3SRU0Rr11KMFJ-8HJU9nmZGSvc-04T2cEAqv5w5BZeKndI-hJoZ6gGfi7LDSy0VaIEgQJwRssKTesDAzF7Uo5dCiduG8LjF1ecfz2yMPAeTB0ySnNoFBMNUSM13upqWFw9BjxB9G2fBcUjKmustj1wf5FUF31rbJtGFUeH0ZxpvbSCUJg4DrplbNuYtSmmtqMWg99CXBQBXYD5hknMjZ416PJ-MQqbM3CT2NnVPqaer8cVyllOf0GcJrbqQ19XiSm8bHUhI0va_MqrH2X2FdOkg85Ry7mKdZJNmWCIGbqtxrV9Mlbiibf-_uYG5zkhlM8c15STb6iUZm1d8fYvD=w1600-h707-no
3*AAA coast headlamp, the Defiant 3C triple led, an 18650 wrapped in water bottle plastic to increase it's diameter to C sized, an 80mm spacer, a spare 18650, and a dorcey 28 inch 2D traffic wand.
ven
Manchester UK
That looks a decent light , for $10 .....wow!
Wish we had a Home Depot
Beam should be a mix of decent throw and generous spill ,presume like a Mickey Mouse shape!
Poppy
Northern New Jersey
When I see lights like this, it makes me wish I had a lathe, so I could cut the body to the length of a 26650, or 18650, and re-thread it.
Certainly I have better lights, but for $10 ? That's just crazy.
RWT1405
PA
As bykfixer likes to say, "Even a bad light ain't bad these days."
For $10 dollars that's worth taking a chance.
Poppy
Northern New Jersey
I was at the store today to get O rings for my power washer. I didn't see the light there, and didn't have time for mess around.
But I just ordered one for pickup at the store.
Maybe tomorrow I'll get it.
mikekoz
Went by a Home Depot today that was showing 26 of them in stock, at $8.00. Could not find a one, and neither could one of their employees. :fail:
Poppy
Northern New Jersey
Beam should be a mix of decent throw and generous spill, presume like a Mickey Mouse shape!
Yes, ven, you called it! :)
The hot spot is like a three eared mickey mouse.
The corona is like a rounded triangle
and the spill is like the leafs of a flower, 9 leaves in all.
It's really only noticeable when white wall hunting.
If you like C cell lights, it is definitely worth $10
TREX3
There's a shocker. Locally our Home Depot and Lowe's employees cant find their rears with both hands
bykfixer
Dust in the Wind
Probably in the back somewhere. I had a manager look for some Mag specials as the computer said there were plenty.
Turns out they were still in the shipping carton and just hadn't been set out for display yet.
Poppy
Northern New Jersey
While it has high low and strobe, it appears the driver is in the switch, because when I jumpered the negative pole to the body it came on high, and didn't advance to low or strobe with a quick disconnect and reconnect.
EDIT: I changed the numbers below because I measured through the switch
I measured the amperage on HIGH and got 800 ma.
With a drain like that I expect to get about 2.5 - 3 hours hours of decent output on high, They claim 3 hours, but you know that is to the FL1 standard of 10%.
On LOW I measured 80 ma. according to HKJ's battery tests, it should get about 60-65 hours.
With a spacer and an 18650 battery I expect to get about 3 hours on high, when it will drop off rapidly. On low I estimate that it will get about 35 hours.
EDIT END...
The light itself has some heft, but the lens is a thin plastic, I suspect that it will scratch easily, but it is recessed enough that you would almost have to try to scratch it. Both ends of the tube are spring loaded which would help it to take some abuse.
One thing that is nice about 3C cell lights is that you can use adapters and run it on eneloops, or 18650's, or alkalines, or C NiMH batteries.
Poppy
Northern New Jersey
I just did a run-time test with this on high with a 3400mah protected 18650.
The driver is of the type where it starts high, and gradually over 20-30 minutes dims by about 30%. This extends the run-time of the light. But if you turn it off and then back on, it comes back on high.
In this test, I turned the light off, and then back on, every 30 minutes, to get it to run on a fairly steady HIGH output.
It ran for 4 hours, and then shut itself off. The battery came out at 2.93 volts.
Poppy
Northern New Jersey
These lights are no longer available.
According to home depot customer service. They must have been a promotional limited run for last year's "Black Friday" or something like that.
I'm happy that I got two of them
Hooked on Fenix
Took a look at these when I saw them at Home Depot today. Was surprised to see that they updated the l.e.d.s from XP-G2 to XP-G3 l.e.d.s. Got one when I saw that and that they were $10. Compared to last year's model, this one has a faceted reflector, so less throw but more flood light and the light is a little shorter than the older model. I was under the impression that these lights had an auto shutoff at 3 hours (at least last year's model did), so I wouldn't count on ANSI specs for runtime data.
bykfixer
Dust in the Wind
Well thanks to a fella named poparalis I have one of these bad boys in the collection.
Two words: Not Bad!
Tailstands, has pretty good grip, not very heavy, and did I mention it tailstands?
Nothing fancy. Bout like an old Maglite with a rear clicky
Speaking of rear clicky.... it's a reverse. It's the kind you have to cycle through the 3 choices to turn it off. Being reverse it seems more efficient in use as the 4th release is the off. Saves a stroke vs forward clickys of this type.
Not Bad.
Did I mention it tail stands?
The little orange line is the diagram of a planned hole to be added for a wrist lanyard. Once I had 35 lanyards in stock. Now I have 0 so there won't be a rush to drill it.
I did try a couple of twists to see if that locks it out... nope. Oh well.
The business end.
No more Mickey Mouse ears or odd corona on this version.
In real world use this WILL DO!
But does it throw?
Dusk. Next door neighbors photo sensor light aint on.
Yes...it throws.
Turn off photo sensor lights? Well I suppose a bit closer would be required due to all of the difussion.
I'll probably use low the most.
I'll do the 18mm thing at some point too.
Bottom line...
Not Bad. Not bad at all.
2016/17 is a great time to buy a flashlight.
Poppy
Northern New Jersey
I noticed that these are on sale at only $8 online. It says that they are not sold in the stores, but when I went to my local home depot, they had a full display of them, perhaps 30 or so. They had both styles in stock, one blue labeled, the other yellow/orange labled. One had smooth reflectors, the other faceted (like the photo bykfixer posted).
The smooth ones that I have, have a pretty neutral tint, the faceted one that I have has a more cool white tint. I don't know if that was the luck of the draw, or if that is something that can be counted on.
In either case, in the store they were listed at 12.88, marked down to $10. But I am sure they would honor the $8 online price. Just bring your smart phone.
At $8 it is a gem of a light. I imagine that once they are sold out, they won't be replaced until next Christmas.
