Does anyone know which optic is used in the Delta with Nichia 219c? Mine is the spot but I can’t find any info about it beyond that.
Is it a Carclo 105 series?
Can other Carclo optics be swapped out?
Is the glow board the same as a turbo glow?
If not, will the turbo glow board that Illumn.com sells work?
Can they be owner swapped?
Help please, thanks!
Hi,
Yes these can be user changed by unscrewing the bezel.
The ones Illumn is selling appear to have GID plastic in itself? Not sure, but if it's 20mm it might fit.
The Delta's glow board is a GID plastic that sits under the optic and is a separate piece and also removeable.
Carclo makes two other 20mm tri-optics the Narrow Frosted and Elliptical that also fit the Delta/Alpha Carbon/Alpha Shorty Triple lights.
Here's some info from the website:
Spare optics for your Delta Flashlight
Tune your beam profile to your liking!
These are standard 20mm Carclo optics that work with a range on Nichia 219/319 and Cree XPG LEDs.
Please note: in order to fit the optic in a Delta light you need to use a sharp kinfe and trim off the small "runner" that is an artifact of the injection molding process (see photo #2). It is only important that this runner not stick out beyond the outside diameter of the optic. This is to prevent it from getting jammed inside the pill.
Here's a few pics of mine:
Delta 319A Wide
Delta 319A Medium
Delta 319A Narrow
