whitenoise
Heh, I had actually thought the same thing after I had posted it 🙂 Ah well it killed a few minutes whilst waiting for the end of work 😉 Tests were interesting though.
Help Support Candle Power Flashlight Forum
Here is a beam shot for compare the spot (8°) and the flood with 36°.
Both beams are have not any spill.
Michael
I was reading over on the DIR forum, it would seem the the dir crowd are quite against the idea of a focusable light and different levels of brightness.
or DDL ?
You all read only on half - what about ATON lightor DDL ?
IT MUST BE FOCUSABLE!
Dont get hung up one what one or two DIR divers say they want in a light. It does not mean all DIR divers want or should have it like that nor does it mean you should either.
I read that thread and found most of it bollocks.
Magnetic switches are very reliable when designed correctly . Much more so than a switch in a condom and in some set ups could add redundancy
Multiple power levels with LEDs are also very reliable and no less so than a single power level. Although I would add that 2 power levels are all you need and any more levels or modes just add unnecessary complexity. In saying that I do use 3 level drivers but only because the driver does evey thing else I want.
The DIR/GUE/UTD system have some very good ideas many of which I use in my diving. Not because they are DIR but because they are good ideas which is why DIR use them in the first place.
I agree
I am unaware if there is a DIR requirement for a single mode light. I doubt it. I think its probably more of some DIR divers deciding that less is more and less features mean a more reliable light.
That is correct..
As for the VB-50, if you dont want the adjustable focus why buy it? Its the best feature of the light and I would guess adds a lot to the cost.
Because of the top picture below..
