Packhorse
Yeah. If you can get a 25.4mm x1.5mm tap it would be easy but its an odd ball thread.The one hard step is if you can get the threading done. The rest is simple DIY stuff (simple being anything I can do)
Help Support Candle Power Flashlight Forum
it's an easy mod from Packhorse's can light to a hand light.....The rest is simple DIY stuff....
What LED to use?
With a single 18650 driving a SST-50 at 50% will give you less than one hour. Simply not long enough. Sure you could run it less but why? To many compromises.Wasn't the idea way back at the begining of the thread to use a SST-50, with aspherics, in a hand-held?
Thats because its all about me ME ME ME!!!!It does seem like this thread has gone in a slightly different direction that I had hoped. Then again thats just me being selfish :devil:
it's the effects of advancing ageIt's almost as though all of the (IMHO good) ideas from the start of the thread have been forgotten through the discussion😕
Why the change of mind though? Looking at the very early posts in this thread, you seemed keen on 2 x 18650's/26650's and seemed quite keen on a hand held and can light. It's almost as though all of the (IMHO good) ideas from the start of the thread have been forgotten through the discussion 😕
Pardon if this has already been shown in this thread, but I found this today and though it was a novel idea of using both a reflector and lens for adjusting the focus:
LED LENSER Technology ...
It really came down to simplicity and what I really wanted now for my own use.
There seems to be a growing number of focusable hand helds available now. So the question becomes can I make a better one or a cheaper one?
Just had a brain wave about an adjustable focus system....
I will present in some days pictures of our new focusable LED head. Yesterday i got the prototype of our VB-50. This LED-head works also as a HAND LIGHT together with the battery-housings of our PHOTON or PHOTON2....
What LED are you using?
The SST-50 !
Assuming enough surface area exposed to water to cool down the tower which holds the LED, no, I don't see anything wrong with it. Sounds like a great idea. You can even add an external screw that would put pressure on the tower/piston for those folks who want to stay at a particular focus setting for longer periods (set and forget it type of operation).The idea is so simple there must be something wrong with it.
@ all
@ Whitenoise
http://www.mb-sub.com/photon/?L=2
or
http://www.mb-sub.com/photon2/?L=2
The burning time with the small battery pack (12,6V-1,6Ah) will be > 1hr with 100% power setting (approx. 1250 lumen).
The second power step will be only 35% electrical power, this is equivalent to 50% of the light power.
The burning time with the battery pack of the PHOTON2 will be double.
The focus can be changed between 8° and 36°.
Logically this head will not be cheap.
Michael
