I have an LED desk type lamp - one of those things with a flexy adjustable stem and a clip at the end of it.
To cut a long story short, it appears that the emitter is damaged. I took it apart and there is still approx 2V DC going to the emitter base (sorry not sure what the correct term may be) but the actual emitter only works if, after switching on, I fiddle around with pressing it directly.
Could anyone advise what part I should buy to replace this?
The circuitry is separate, and apparently fully functional (as per the above testing showing 2V) the base and emitter have no electronic parts attached.
A base that is a nominal 20mm in diameter will fit.
Thanks in advance for any advice!
