Have done some testing now and I like it! It is very tough. As you can see in the graph I was able to push it to 2,5A. Then it was shutdown by the thermal protection. When I turned it on again it worked like before. This happened many times during the 2A+ tests, until I put an extra heatsink on it. It wasn't really stable over 2. Had it on 2.2A for 5 min, but then it got too hot and shut down.
The test setup:
Old computer PSU
Mulimeters (Vin, Vout,Iin,Iout)
8A rectifier diodes as load. (didn't want to risk my MC-E)
Modded driver with dimming, lower R2 and a small heatsink soldered to pin 5 and 6 as suggested bu uk_caver
As you can see there are some variations, this can be because of:
I used the 20A socket on the multimeters and they are far from accurate, but both mulimeters are axectly the same and gives the same value of a current, so it shouldn't influence efficiency calculation too much.
The diodes got hot and VF changed slightly, this is of course measured and in calculation.
The dimming method used is not very temperature stable.
-A real amateur test
Here are some pictures of the board:
To do the dimming mod you have to cut one of the tracks on the board. (see picture)
Then solder A potentiometer and a resistor as shown in picture.
If you want higher output than 1A you need to change R2 to a lower value. Look in the
data sheet for resistor values.
Heatsink with ugly soldering, sorry
