plasmaman
Anyone know what spec these A123 cells are that Dewalt are using in their new battery packs?
Hello Plasmaman,
Here is the data sheet for the larger cells.
The people using the DeWalt power tools have been very pleased with the stock charger. If you are planning on using the stock pack, the stock charger should work very well.
The RC people are building custom battery packs, so the stock charger is not appropriate their use.
Tom
I have GOT to get that next batch of JM-SSTs out the door so I can build the L14K model.
40V Vin max, and 50A no sweat. 20A will be a walk in the park. I've been doing some work in the last hour or so. I've found a nice driver that can drive multiple mosfets. Still on paper, but the JM-SSTs are ready to have their components populated. Sad thing is I'm away from home next week for work.You have - and presumably it will be OK with 30 - 36v Vin, and 20A draw?
Hello Plasmaman,
The stock charger has temperature probes, as well as a cell balancing system. If you hook up all of these safety devices, I don't think there would be any reason that would prevent you from using the stock charger.
Just make sure you take notes when you take the pack apart and get everything hooked up properly when you put it back together.
Tom
