Dexlight Sapphire Crystal 3W 16-mode CREE AA/14500 Flashlight Kit
ow!myeyez
45 bucks for this. yay or nay??
does anyone have an invitation number code?
http://www.dealextreme.com/details.dx/sku.2888
Lamp Type: CREE 7090 XR-E P4
Lens: Sapphire Crystal
Maximum Output: 150 Lumens
Switch: Multi-mode Water-tight Non-Reverse type G-I-T-D Tailcap
Lumens Reflector: Textured aluminum reflector
Body Material: T6061 aircraft grade aluminum
Finish: HA III NAT [TESTED: 45µM (+-5%) Hardness 400HV]
Battery Type: AA or any AA-size battery (including 14500)
Accepted Voltage: 0.7V-4.2V with reverse-polarity protection (won't burn if battery is incorrectly installed
Flashlight Modes (Basic):
Default Brightness – Lowest Brightness – Maximum Brightness – Medium Brightness – Strobe – Standby (blinks every 60 seconds)
Advanced Modes: 11 levels of output & 6 special function modes (click here to see complete chart)
Switch: Non-reverse type clicky On/Off GITD Tail Cap (press half way / soft press to change modes)
Water Resistance: 30 ft.
Dimension: Bezel diameter 19.5mm, Tail diameter 20.5mm, Long 90mm Weight: 40g (excluding batteries)
Comes in sealed Dexlight retail packaging with the following items:
- Spare o-rings
- Nylon Dexlight holster
- Carrying strap
- Four tail caps in: Red, Black, Orange, and Yellow (Glow-in-the-dark)
- Detailed user's guide (English)
Some of the pictures show an Ultrafire 14500 battery. It's for size comparison purposes only and is sold separately.
Dimensions: 3.62 in x 0.71 in x 0.71 in
Weight: 1.6 oz
