Kyle (Sonny Chen) of DealExtreme.com sent me a pre-production of the Cree XR-E based DEXlight X.1 (link) for review
The "DEX" comes from Deal-EXtreme.
Size
smaller than the Fenix L1Dce, slightly longer than the Fenix L1T, same diameter as the L1T - but the tailcap widenes slightly the very end.
The color is HA3 black - but in real life it is a very dark grey with a slight hint of brown - actually very attractive.
Head -
The DEXlight X.1 uses a stippled/textured reflector.
Nice touches -
double O-rings at both ends.
gold(?or just colored?) contacts for the tail.....
Glow-In-The-Dark (GITD) tail-switch cover - the switch is a reverse clicky - it clicks ON then there is momentary OFF by tapping or slight depression. This makes switching modes easy - similar to the Fenix L1D-CE.
Although the DEXlight X.1 is basically uniform in diameter (except at the very end of the tailcap) its body tube is noticably thicker at the head than at the tail.
Being a pre-production review sample Kyle has notified me of some known issues which are to be addressed for the full production units -
The lower levels from max at by PWM - at 100Hz for the pre-production review sample - but to be 200Hz for production.
I see that ernsanada has already posted his review - Dexlight X.1 3W Cree - where he has shown it using 3.7V rechargeable Li-Ion 14500 (AA size).
So to complement his review I'll look at the DEXlight X.1 using plain Alkalines and NiMH rechargeables -
Alkaline AA -
vs. Fenix L1D-CE both on Alkalines and maximum brightness -
hard call to make because oof the tint difference - biut I think the Fenix L1Dce is very slightly brighter - but the DEXlight X.1 shows less of the dark halo.
vs. Fenix L1T both on Alkalines and max brightness -
not surprisingly the Cree XR-E based DEXlight X.1 is substantially brighter than the 3watt Luxeon III of the Fenix L1T
NiMH AA rechargeable -
vs. Fenix L1D-CE both on NiMH and max brightness
similar results to the alkaline comparison - similar brightness with perhaps a very slight edge to the Fenix L1Dce.
similar results to the alkaline comparison.
The DEXlight X.1 has several modes - the best is to quote the specs from the DEXlight X.1 page -
QUOTE:
Flashlight Modes (Basic):
Default Brightness – Lowest Brightness – Maximum Brightness – Medium Brightness – Strobe – Standby (blinks every 60 seconds)
Advanced Modes: 11 levels of output & 5 special function modes (click here to see complete chart)
END QUOTE
Issues -
When using 3.7V rechargeable Li-Ion 14500 I seem only to get the advanced modes (click on the link in the quote to see the modes) - I do not seem to be able to get to the general modes.
On Alkaline or NiMH - on my review sample I would get initially High > High > Medium > fast strobe > standby
Then it would appear to behave and give the spec'd general modes.
But occassionally I would get that "strange" initial state and I cannot work out when I may get it.
If I do get that "strange" state - changing the light to standby would get the light back on track to the general modes.
This could cause a bit of uncertainty to which brightness I might be on for the beamshots -
however I always switch the modes until I got the correct sequence and then double checked by waving my open hand in front of the light to make sure there wasn't any PWM - so I was sure of the max brightness.
Also in standby mode the light flashes about once every 6.5 secs on my sample.
The threads do feel a bit touchy with a possibility to cross-threading - and I am pleased to see that is a known issue to be addressed with wider threads for production - hopefully that will make the threads smoother.
I do like the light - although I feel it may have too many modes which may make things confusing - of course my pre-production sample's "strange" behavior doesn't help.
The one big change that I would like to see is either a selectable default brightness on first switching on (I would choose low) - or just make the inital brightness Low. I know others may prefer max brightness - the first option of selectable default brightness - would allow everyone to tailor their own initial brightness level.
see also CPF discussion -
Dexlight 16-mode CREE at DX
Size
Head -
Nice touches -
Alkaline AA -
END QUOTE
Issues -
