Here are my first impressions on the Dexlight X.1 from Dealextreme.
* All modes are accessible on 14500.
* PWM is used on all modes except high, frequency measured to 120Hz.
* Comparisons with my closest match, C-LE - lux readings at 1m :
[email protected]
X1: 600, 60, 670, 230
C-LE: 300, 60, 650
[email protected]
X1: 480, 55, 570, 200
C-LE: 260, 55, 580
[email protected] (Ultrafire "900")
X1: 1600, 150, 2000, 700
X1: 1500, 140, 1800, 630
3V Primary Li [email protected] (from CRV3 battery)
C-LE: 550, 110, 1200
X1 modes: default (80%), low (5%), high (100%), med (30%)
C-LE modes: med, low, high
Current on [email protected]: 1200mA, 100mA, 1500mA, 480mA
Current on [email protected]: 1070mA, 96mA, 1300mA, 400mA
Beacon frequency is 1/6 Hz i.e. one blink every 6 seconds.
Advanced mode is entered by pressing button 2+ sec on low.
Getting back to basic mode press button 2+ sec on either strobe (5/15Hz).
Well centered led and smother op than the C-LE.
Beam is free from artifacts and has similar shape to C-LE, the X1 has a warmer tint though.
Thread action is ok after removing some metal shavings and re-lubing o-rings.
The only problem is to properly engage the threads since one o-ring hits the head/tail-cap before the threads does :shrug:
The tail-cap button has a nice texture which is fortunate since it requires at least twice the force compared to Fenix.
Personally, I think it requires a tad to much force while the Fenix is a bit to weak for my taste.
Two minor dents in the dark gray/brown HA, no big deal.
Serial number is 7Q2-07050171 - slightly different font on 0171, so this must be #171.
** UPDATE 05-31-2007 **
I ordered a new AW P14500 from Fenix Store and it does not fit.
It's almost 51.8mm, X1 tube length is 51.3mm.
52mm tube or 51mm cell and it would have been ok :shrug:
The fix is the same as P14500 in L1T - add a thin ring of copper wire or similar at one end.
In my case I added a loop of wire in the tail-cap and ta-da P14500 works.
Still happy with the light, Cheers!
/Alex
[email protected]
C-LE: 300, 60, 650
[email protected]
C-LE: 260, 55, 580
/Alex
