Icebreak
I modded a Cold Steel Brute a few years ago. I've been meaning to show this proof of concept for a while. Maybe it's proof it's a bad idea but I still like the idea.
D26 is a good form factor for me. I can stuff these sized lights in pockets and other places. They are easy to deploy rapidly. I want more power. I didn't get FiveMega's D26 but it looks good. My "Brute66" has a ground down Pelican PM6 27mm OP reflector in it. It runs a Welch Allyn WA01166 off of 11 2/3 AA 750 mAh NiMh cells. Here's some comparison shots. Forgive me. I'm still learning. The focus and exposure were locked. It was set to Day Light.
Distance: 135' or 45 yds
Malkoff M60 on 2 RCR123 Li-Ions
SF P91 on 3 CR 123 primaries
Lumens Factory D36 EO9L
Brute66
Same shots poorly cropped:
Brute66
There are a couple of problems with the concept of going this strong on a tiny light. The WA1166 is pushing a lot of spill which is nice but it sure doesn't punch like a big OEM Mag reflector. Also, even though that Pelican 27mm OP is a wonderful parabolic design it is not as efficient as a larger reflector. Heat can be a problem within a few minutes. The Brute66 handles it just fine but lesser masses would be challenged. The 1166 using relatively low amps is a plus for runtime but a minus for battery size as you can see. Still, I would like to have a Z3 to Z4 sized light that would pump out a ton of light, easily carried and easily deployed. I think it can be done if the right lamp/battery combination can be identified. What do you think? Is it doable?
Z3 P91, Brute66, 6P Malkoff M60 all lit up with the side spill from a ROP. Notice the dirt looks like dirt and the grass looks like grass.
Bonus critter eyeshine shot taken on another day using lower exposure settings. This is a Z3 with a P91. I don't know the critter's first name but I'm sure it begins with an "R".
Brute66
Brute66
