Re: Difference between voltage & current regulatio
Hello there,
In addition to the other great posts...
Let's try to answer a few questions about running LEDs properly
in an order that might clear things up a little...
What is a constant voltage source?
What is a constant current source?
What is the difference between the manufacturers 'voltage' specification
and the manufacturers 'current' specification for an LED?
We'll find that the answer to this last question really helps us
find the answer to the best way to run an LED, but knowing the
other two helps also 🙂
A constant voltage source is a source of energy that will keep the
voltage level ACROSS an object the same regardless of how the object
changes internally, with NO REGARD for what the current level is.
A constant current source is a source of energy that will keep the
current level THROUGH an object the same regardless of how the object
changes internally, with NO REGARD for what the voltage level is.
Now the manufacturer of the LED gives us various guidelines to
go by when designing circuits for LEDs. Some of these guidelines
include specifications that MUST be followed VERY CLOSELY and
others are just general guidelines or typical running specs
which arent exact for every single LED but just typical ratings.
This means there are two basic types of specs given by the
manufacturer so we can run LEDs in circuits:
1. Specs that must be followed closely.
2. Specs that are just typical of most of these kinds of LEDs.
Now we are ready to ask the question:
Is it better to run an LED with a constant current or a constant voltage?
We look first at the LED specs, sorting them into one of
the catagories above...
THE 'CURRENT' SPEC:
The manufacturers CURRENT spec for an LED says what the led can
stand in terms of current through the device, and if it goes over
a certain LIMIT the led might blow out. This is very important to know!
We put this into catagory #1 because it has to be followed
very closely. If we dont get this right or something about
the led changes with time we blow out the led long before its
useful lifetime. The current through the device must therefore
be correct at all times, or at least below a certain LIMIT point.
THE 'VOLTAGE' SPEC:
The manufacturers VOLTAGE spec for an LED says what 'typical'
voltage MIGHT be present when the led is in operation, especially
around the recommended operating current level.
We put this into catagory #2 because it's just something about
the led that is likely to occur when running the led in a typical
circuit. We should also note that this is NOT A SETPOINT!
We cant really set the voltage at a particular level and expect
the current to be correct, because the operating voltage
changes with temperature as well as from package to package.
The answer to our last question should be obvious now...
Since the 'current' specification is so important to running
an LED properly (if it changes by much it might blow out)
we really have to regulate the current through the device,
not the voltage across it. The voltage the LED will operate
at might change a little while running but we dont really
care that much as long as the current stays at a safe level.
With the constant current source we set the current at a certain
level and know it will always be correct regardless of what
happens to the voltage, so we can be assured that the
device will operate correctly for a long, long time.
If we try to regulate the voltage what happens is we get
the correct current level while we are setting it, but then
later when the temperature changes we find the current
has changed! Not only that, if it decides to change to
a much higher level the LED blows out!
Needless to say, this is not what we want, so we dont regulate
the voltage.
BTW, the LED is known as a 'current operated device' because
the current is the most important parameter and is the
parameter to set when designing a circuit for an LED.
The current is the 'primary' parameter, while the voltage
is the 'secondary' parameter.
Yes, it's good to know what the voltage is, but it's better
to know what the current is.
Good luck with your LED circuits!
Take care,
Al
