What kind of AAs? Carbon, alkaline, NiCd, NiMH? Even lithiums come in AA form, with 1.5 and 3 volt models both available.
Assuming you meant alkaline AAs, while two lithium 123s and four AAs each provide a nominal 6 volts, the voltage under load may be quite different, depending on how much current is being drawn. Lithiums can generally provide more current than alkalines for a given voltage.
So if you're talking about a Luxeon Star, an optimal solution may involve using different resistor values.
But in the case of single 20mA LED, I wouldn't think so.
