difference WF-138 and WF-139
gravityz
The Netherlands, yes way below sealevel
can anybody tell me the difference in charghing circuit of these
in another thread the wf-139 is discussed but i can not see anything about the WF-138
the charging circuit is about the same
if anybody has an opened wf-138 and can tell me the value of the resistors i can check with my wf-139
only take the resistors which have a normal size. the smd types are top small and are probably not interesting
You know the 138 does both 3.6 and 3.0 volt? Any differences are related to that I'm sure. Are you trying to convert a 139 to do 3.0 also?
no it seems that chargingcurrents are different so i try to match the current of the WF-138 with the wf-139(for the 10440)
i allready tested that 1ohm in series with the 10440 will give me roughly 300ma
i tested this last night by replacing the 0.22 restistor with a 1.22 ohm resistor
well probably did not look right at the flowchart because this results in a 60ma current.
i think this is because the r5/r6 voltage is divided by other resistors and then feed back to the LM393
i calculated r5/r6 and indeed if you make this 0.33 ohm(same as wf-138) you will get 250ma so that is what i will do
moify one bay for 10440 and leave the other standard.
i checked on the wf-139
R24/R24(not R25/R26)=10K
R31/R32=220K
D11/D12=330 ohm (why the hell is this low resistor in series with a high one)
if anybody can give me the same resistors on the WF-138 that would be nice. those i need are R14/R28, R21/R15,
thanks
