direct driving 4 LuxIII?
Turbo_E
Turbo_E
can i do it in series with 3 D NiMh cells?
wtraymond
wtraymond
Milwaukee, WI
You can wire each emitter in parallel and run all three direct drive from three NiMH D cells, but you'll be drawing 3-4 amps out of those batteries.
I'd recommend a boost convertor like the Fatman or Shark to drive four emitters in series. Use a battery holder to fit eight or nine AAs in a 2D or 3D host and boost the voltage to VfTotal. You should use low Vf emitters like 'H' or 'J' for ongest runtimes.
C
cy
USA
barbolight U-09 runs 3x Kbin luxeons in direct drive. wiring is in parallel. draw is aprox. 2.7 amps with fresh cells, then drops back.
you need to use 3x nmh Cells to do this properly. nmh have a fairly flat discharge rate.
DFiorentino
DFiorentino
MD
I ran 4 K-Vf LuxIII in parallel with 3D NiMH in the past and only pulled 2.5A on fresh cells (.625A per LuxIII). The same setup with 4C NiMH (in a 3D Mag) pulled 3.6A on fresh cells (.900A per LuxIII :rock: ). If I were to do it again, I would use some J-Vf on 3D NiMH.
-DF
C
cy
USA
DFiorentino said:
I ran 4 K-Vf LuxIII in parallel with 3D NiMH in the past and only pulled 2.5A on fresh cells (.625A per LuxIII). The same setup with 4C NiMH (in a 3D Mag) pulled 3.6A on fresh cells (.900A per LuxIII :rock: ). If I were to do it again, I would use some J-Vf on 3D NiMH.-DF
what type of meter did you use?
I'm using fluke 87's for accuracy
DFiorentino
DFiorentino
MD
Ideal 61-360. I know it's not "branded", but I did compare it against a few Flukes we have at worked and I saw no difference in accuracy.
-DF
C
cy
USA
if you calibrated meter against a fluke, then it's reasonably accurate.
I'll have to recharge my 3x C nmh and remeasure.
Turbo_E
Turbo_E
i forgot to mention i'm using 4 X SX1K binned luxes, so parallel will work on 3 D's?
C
cy
USA
sure it'll work, it's a question if your 3x D nmh cells will support that many amps.
IsaacHayes
IsaacHayes
Missouri
Turbo, Yes, 4 SX1K in parallel to 3D NiMH would be great. If your NiMH are good brand and capacity, then youre set.
I use titanium C NiMH 5000mah in my tri-lux w/ TX0K and it pulls right around 3.1amps fresh off the charger. Like 2.6 or something when they have sat for a long time.
Good 10000mah+ D cells would give you decent run time.
C
cy
USA
ok, retested barbolight U-09 for current draw with fluke 87
with fresh off charger 3x C nmh cells 2.753 amps
after cells sitting for overnight 2.674
M
mpf
What is the voltage burden of you meter?
That is how much voltage does the meter use just measuring the current.
This can affect your measurements.
An alternative is to measure the voltage across the leds and then as a separate test drive the leds to that voltage from a power supply and measure the current.
Need to do this quickly to avoid heating effects on the led Vf
matthew
Turbo_E
Turbo_E
thanks guys. I'm building a ROP and was thinking of reusing my 2D mag, currently holding the 4 LuxIIIs.
the 4 will be shuttled to a 3 D mag.
IsaacHayes
IsaacHayes
Missouri
Should work well with the K bin Vf and NiMH. Let us know! I'd do a quad mag but I like to use C's, so runtime woulnd't be that great. So I stick to my lowely tri-mag! :)
Similar threads
737mechanic
Replies
12
Views
3K
737mechanic
737mechanic
F
Replies
10
Views
3K
f22shift
f22shift
ResQTech
Replies
33
Views
1K
LEDmodMan
LEDmodMan
Buck91
Replies
1
Views
1K
Fallingwater
Fallingwater
