brembo
- Joined
- Jun 14, 2011
- Messages
- 203
Been banging around in the battery university and poking around in this subforum and I'm still at a loss.
I have a pretty good grasp of what 1C rates are, a 2000mAh cell discharged at 1C will in theory be 2000mAh in one hour. A .5C rate will take two hours, and a 2C rate will take 30 minutes. Easy-peasy there.
Now this is where I get all confused. As I understand it, the higher the cell's rated mAh, the more internal resistance. Li-ion cells in general are not supposed to be discharged above 2C(correct?). So, a 2000mAh cell with (theoretically) less resistance than a 2900 mAh cell is not supposed to deliver 5800mAh (rate) while a 2900 mAh cell is (again, theoretically) okay in that situation? What critical bit of info am I missing here?
Is capacity tied to max discharge rate, with little regard to resistance? Or am I reading too much into this "rule of thumb"? It seems odd that the discharge RATE is linked to the overall capacity.
I ask this as I have a single cell 14500 light that rides the bleeding edge of 2C with a 750mAh cell (little over it in fact). I'm using AW cells in it, so I'm in good shape there, but any steps in the direction of safety are welcome. I could always just get an IMR and forgo a little bit of capacity, still I'd like to know the relationship of capacity to discharge rate in "typical" Li-ion cells.
*edit*
Fixed a few calcs.
*edit*
Fixed a few calcs.
